DaveC Posted November 8, 2018 Share Posted November 8, 2018 I need to load the "ACAD Cui" with lisp but only the "File, Window & Help" pull down menus are visible. I'm following the sample in this link.. http://www.cadtutor.net/forum/showthread.php?26379-about-load-CUI-file and I listing every single Pull Down Menu, but is not see the pull downs. (setq AcadPath "C:\\Users\\<<username>>\\AppData\\Roaming\\Autodesk\\MEP 2018\\enu\\Support\\") (setq cui_database (list "ACAD" ;<<< MENUGROUP (strcat AcadPath "acad.CUIX") ;<<< PATH & CUI FILENAME "&File" ;<<< MENUNAME "&Edit" ;<<< MENUNAME "&View" ;<<< MENUNAME "&Insert" ;<<< MENUNAME "&Format" ;<<< MENUNAME "&Tools" ;<<< MENUNAME "&Draw" ;<<< MENUNAME "&Dimension" ;<<< MENUNAME "&Modify" ;<<< MENUNAME "&Parametric" ;<<< MENUNAME "&Window" ;<<< MENUNAME "&Help" ;<<< MENUNAME ;"&Power" ;<<< MENUNAME ) ;_ end_list flag nil ) ;_ end_setq I need to load ALL the pull down menus, please help. thank in advance. DC Quote Link to comment Share on other sites More sharing options...
ronjonp Posted November 8, 2018 Share Posted November 8, 2018 I thought by default all pulldown menus load if MENUBAR = 1 (setvar 'menubar 1)? Maybe your CUI is borked. Quote Link to comment Share on other sites More sharing options...
DaveC Posted November 8, 2018 Author Share Posted November 8, 2018 Thank you RONJONP, the CUI is the original default from Autocad, if I loaded manually by using the command CUILOAD it load all the pull down menus, the problem is if I use LISP. and Yes my MENUBAR = 1 Quote Link to comment Share on other sites More sharing options...
DaveC Posted November 8, 2018 Author Share Posted November 8, 2018 - I GOT IT... I used a different method/lisp, (defun ACADCUILOAD ( / old_cmdecho old_ribbonstate) (setq old_cmdecho(getvar "cmdecho")) (setvar "cmdecho" 0) (setvar "MENUBAR" 1) (if (not (menugroup "ACAD")) (command "cuiload" "C:\\Users\\<<USERNAME>>\\AppData\\Roaming\\Autodesk\\MEP 2018\\enu\\support\\ACAD.cuix") ); end IF (menucmd "p1=+ACAD.POP1.FILE") (menucmd "p2=+ACAD.POP2.EDIT") (menucmd "p3=+ACAD.POP3.VIEW") (menucmd "p4=+ACAD.POP4.INSERT") (menucmd "p5=+ACAD.POP5.FORMAT") (menucmd "p6=+ACAD.POP6.TOOLS") (menucmd "p7=+ACAD.POP7.DRAW") (menucmd "p8=+ACAD.POP6.DIMENSION") (menucmd "p9=+ACAD.POP6.MODIFY") (menucmd "p10=+ACAD.POP6.PARAMETRIC") (menucmd "p11=+ACAD.POP6.WINDOW") (menucmd "p12=+ACAD.POP6.HELP") (setvar "cmdecho" old_cmdecho) (princ) ) Quote Link to comment Share on other sites More sharing options...
