sandiegophil Posted November 13, 2018 Share Posted November 13, 2018 Hello all, I have an issue with my surface spot elevation labels. They work correctly in 2016 but in 2018 the value does not update interactively/dynamically as I drag it around on a surface. I only see the value change when the new point is selected. I am guessing there is a variable I'm missing or not setting correctly. If you have any ideas, suggestions of fixes I would greatly appreciate the help. Regards, Phil Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted November 13, 2018 Author Share Posted November 13, 2018 issue resolved. thanks to all Quote Link to comment Share on other sites More sharing options...
