Extracting dimensions and prefixes autolisp
Good Evening!
I have a lisp script that exports dimension values to a csv file.
I have modified it to only export selected dimensions which is exactly what I want.
However;
I would also like to export any prefix the dimension has and include it with the exported dimension:
EG:    a dimension of 36" that has a prefix of R should be something like   R - 36,     a dimension with no prefix would just be 36
Attached is my current lisp script:
; Save the Dimension's values to a CSV file
; mfuccaro@hotmail.com
; 2008 May
; Enhancements by CAD Studio, 2012
; Modified by WhoolieShop to include prefix's and only work on current selection.
(setq _dimexpdelimiter ",") ; set to ";" for CSY/DEU...
(defun C:DimExp ( / s tx fn i d dl m file)
(setq s (ssget  (list '(0 . "DIMENSION")))
	tx nil
	fn (strcat (getvar "dwgprefix") "DimExp.csv"))
(repeat (setq i (sslength s))
 (setq d (ssname s (setq i (1- i)))
	dl (entget d)
	m (cdr (assoc 42 dl)))
 (if (not (member m tx)) (setq tx (cons m tx)))
(setq s nil)
(if tx (progn
 (setq file (open fn "a")) ; append
 (write-line "" file)
 (princ (strcat (getvar "dwgname") _dimexpdelimiter) file)
 (foreach x tx
  (princ x file)
  (princ _dimexpdelimiter file)
 (if file (close file))
 (princ (strcat "\n" (itoa (length tx)) " dimensions written to " fn))
Thanks in advance!
Edited by whoolieshop
more info added.
Okay about 3 hours of tinkering have gone by and if i change 42 to 1 I can get any overridden text pulled out, and if I change it to 3, i can get the dimension style names which could totally work.
How would I go about editing this code around the line with 42 to include,   Option 42 AND option 3?  (dimension style names)   Note I also need duplicates exported, NOT grouped together if there are 40 dimensions exported and 20 are the exact same I need 40 values exported to the csv.
	dl (entget d)
Have you looked at using vlisp
(setq obj (vlax-ename->vla-object (ssname s (setq i (1- i)))))
(setq txt (vla-get-TextOverride  obj))
