lamensterms Posted November 22, 2018 Posted November 22, 2018 (edited) Hi, I just started working in a new drafting office, using AutoCAD 2014. There are some strange keyboard and command overrides: 1. The comma key will execute the DIMLINEAR command. 2. F4 will execute QUAD snap, even if I have keyboard accelerator assigned to different snap mode. I have looked through the CUI files and can't seem to find anything obvious, also there is nothing in the PGP file that I could see. Can you guys think of anywhere else that these overrides might be configured? Doing an ACAD settings reset is not an option. Thanks Edited November 22, 2018 by lamensterms Quote
BIGAL Posted November 23, 2018 Posted November 23, 2018 Do a full search for acad.lsp sounds like some one has customised a version along the way , a typical search may find at least 3. Then look inside comparing them. Check your File search path for a acad.lsp thats probably where it is. Quote
SLW210 Posted November 26, 2018 Posted November 26, 2018 It could also be a Windows program, there used to be several you could get, some for free or maybe a custom app by the company. You might check in Add/Remove Programs and/or check the Task Manager and see if you find something. Did you ask your coworkers? Quote
BIGAL Posted November 27, 2018 Posted November 27, 2018 To trhow in the mix digitiser speech smart mice with buttons win os as mentioned I had a keyboard with a broken button the ( just set it to another key. pgp custom lisp Quote
lamensterms Posted November 29, 2018 Author Posted November 29, 2018 Thanks for replies guys. Sorry for the late reply, there were no notifications. It ended up being AutoHook Quote
