amb2301 Posted December 6, 2018 Posted December 6, 2018 Hi Friends, I am having a task to open all drawings(nearly 50 drawings) from a single folder path & plot the layouts to pdf (monochrome), Note: All the plotted pdf to be in a single pdf file. some one help & please provide me the lisp to do this task. Thanks in Advance. Quote
maratovich Posted December 7, 2018 Posted December 7, 2018 Have you tried using Publish? Add an example of your file. Quote
Emmanuel Delay Posted December 7, 2018 Posted December 7, 2018 (edited) Yes, if you open these 50 dwg's in 1 Autocad window, then Publish can make 1 pdf of these open dwg's. Is that acceptable? Edited December 7, 2018 by Emmanuel Delay Quote
gustavobernardi Posted December 7, 2018 Posted December 7, 2018 You can generate a multi-page DWF file with publish, then you can open it in design review and plot to PDF with a installed PDF printer. Quote
BIGAL Posted December 8, 2018 Posted December 8, 2018 You can open 50 dwgs plot a pdf then use Ghostscript to join them all back into 1 pdf. You will need to download Ghostscript its free software. ;MergePdfs ;Merges multiple pdf (or eps) files into one ;Requires the installation of Ghostscript ; make a batch file ? ;gs -sDEVICE=pdfwrite \ ; -dNOPAUSE -dBATCH -dSAFER \ ; -sOutputFile=combined.pdf \ ; first.pdf \ ; second.pdf \ ; third.pdf [...] ;Ghostscript (http://www.ghostscript.com/) can be used to combine PDFs. ; Something like this should work: by Roy_043 (defun KGA_String_Join (strLst delim) (if strLst (apply 'strcat (cons (car strLst) (mapcar '(lambda (a) (strcat delim a)) (cdr strLst)) ) ) "" ) ) ; (CombinePdf ; (setq gsexe "C:\\Program Files\\gs\\gs9.19\\bin\\gswin64c.exe") (setq gsexe "P:\\gs\\gs9.19\\bin\\gswin64c.exe") ; (setq srcFilelst '("D:\\Tmp\\A.pdf" "D:\\Tmp\\B.pdf")) ; (setq trgfile "C:\\Acadtemp\\Total.pdf") ; ) ; Note: Existing trgFile will be overwritten. (defun CombinePdf (gsExe srcFileLst trgFile) (startapp (strcat gsExe " " "-sDEVICE=pdfwrite -dBATCH -dNOPAUSE -dQUIET " "-sOutputFile=\"" trgFile "\" " "\"" (KGA_String_Join srcFileLst "\" \"") "\"" ) ) ) Quote
