Ament Posted December 10, 2018 Posted December 10, 2018 Hi together, I'm breaking my head about a hopefully simple task. Let's start from the beginning. I'm trying to remove attributes like widthfactor, tracking and angle from a MTEXT. Unfortunately these can't be done as simple as for single line text. The attribute values are part of the string. With a few modifications just for testing the string ("TestString") looks like this: (1 . "{\\Q10;\\T0.75;Test\\Q0;\\W0.8;\\T0.9;String}") After removing all attributes the string should become like this: (1 . "TestString") If the widthfactor would be constant (\\T0.75;) it would be simple to write, but as it can vary and also be included between two parts of the final string I have to use wildcards to identify the correct part of the string. My plan is to replace the parts of the string with a just two quotationmarks. First I tried to find a good syntax to check if these kind of attributes are included. I use wcmatch for that: (wcmatch TMPSTR "*\\T[0-9]*[`.][0-9]*;*") But when I try to substitute the part with the following command it doesn't work for me (vl-string-subst "" "*\\T[0-9]*[`.][0-9]*;*" TMPSTR) To me it looks like it doesn't take into account the wildcards. I may be wrong and would gladly appreciate any hint or solution how I can strip my imput string. Best regards, Ament Quote
marko_ribar Posted December 10, 2018 Posted December 10, 2018 Can't you just EXPLODE MTEXT to get TEXT entities... Then simply - strcat - ing... Quote
ronjonp Posted December 10, 2018 Posted December 10, 2018 (edited) You could also use THIS great tool. Or Lee's Unformat String. Edited December 10, 2018 by ronjonp Quote
Lee Mac Posted December 10, 2018 Posted December 10, 2018 (edited) Thanks @ronjonp The function used in this example program (and based on my Unformat String function) is more efficient for repeated evaluation as the RegEx object is supplied as an argument, rather than created/released by the function: ;; Quick Unformat - Lee Mac ;; Returns a string with all MText formatting codes removed. ;; rgx - [vla] Regular Expressions (RegExp) Object ;; str - [str] String to process (defun LM:quickunformat ( rgx str ) (if (null (vl-catch-all-error-p (setq str (vl-catch-all-apply '(lambda nil (vlax-put-property rgx 'global actrue) (vlax-put-property rgx 'multiline actrue) (vlax-put-property rgx 'ignorecase acfalse) (foreach pair '( ("\032" . "\\\\\\\\") (" " . "\\\\P|\\n|\\t") ("$1" . "\\\\(\\\\[ACcFfHKkLlOopQTW])|\\\\[ACcFfHKkLlOopQTW][^\\\\;]*;|\\\\[ACcFfKkHLlOopQTW]") ("$1$2/$3" . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);") ("$1$2" . "\\\\(\\\\S)|[\\\\](})|}") ("$1" . "[\\\\]({)|{") ("\\$1$2$3" . "(\\\\[ACcFfHKkLlOoPpQSTW])|({)|(})") ("\\\\" . "\032") ) (vlax-put-property rgx 'pattern (cdr pair)) (setq str (vlax-invoke rgx 'replace str (car pair))) ) ) ) ) ) ) str ) ) An example function to test: (defun test ( str / reg ) (if (setq reg (vlax-create-object "vbscript.regexp")) (progn (setq str (LM:quickunformat reg str)) (vlax-release-object reg) str ) ) ) Used with the OP's example: _$ (test "{\\Q10;\\T0.75;Test\\Q0;\\W0.8;\\T0.9;String}") "TestString" Edited December 10, 2018 by Lee Mac Quote
Grrr Posted December 10, 2018 Posted December 10, 2018 Lee, just sharing a personal preference: Rather than requiring the caller to pass a RegEx object I think its better to require a list of strings argument, so the iteration will perform inside the subfunciton. i'm saying it, because not everyone is aware how to create RegEx object+knowing that he have to release it (for instance - the OP). Quote
Lee Mac Posted December 10, 2018 Posted December 10, 2018 1 hour ago, Grrr said: Rather than requiring the caller to pass a RegEx object I think its better to require a list of strings argument, so the iteration will perform inside the subfunciton. i'm saying it, because not everyone is aware how to create RegEx object+knowing that he have to release it (for instance - the OP). Then the caller should do some reading before using the function Quote
Grrr Posted December 10, 2018 Posted December 10, 2018 2 hours ago, Lee Mac said: Then the caller should do some reading before using the function Lee, rethinking now.. its fair enough that the caller could use or write a wrapper function, like the example you provided. Its just my style that keeps the execution context within the one certain subfunction (meaning its like just invoking a method and getting something returned, without additional requirements). Quote
ronjonp Posted December 11, 2018 Posted December 11, 2018 7 hours ago, Lee Mac said: Then the caller should do some reading before using the function Totally agree. The amount of detail you provide to use your code takes you out of equation. Quote
Ament Posted December 11, 2018 Author Posted December 11, 2018 Thanks everyone for the help. I'll try this one later. From first sight I guess Lee Mac is right, I should read a bit before using it, but the hints in here are hopefully enough to guide me to the correct path I'll update you if i succeded or need further adivces Quote
Ament Posted December 11, 2018 Author Posted December 11, 2018 Looks really good. It's integrated in my code and is working well. Thanks a lot everyone and especially @Lee Mac. Oftenly when I try to solve an issue in here I find either a routine or some pieces of them in the coding you did already! You can't imagine how much I appreciate your work and that you allow to use it. Thank you! Quote
Lee Mac Posted December 11, 2018 Posted December 11, 2018 You're most welcome, I'm glad that you found the code & my other contributions useful. Quote
