Hi friends, anybody can help me how to solve my problem regarding this dialog box attached. I want to wblock the drawing so that it will reduce the size of the drawing, unfortunately it doesbt work to this drawing. Thanks in advance
Proxy objects in drawings [support Assistance: ASA]Proxy objects in drawings [support Assistance: ASA]
Issue
Proxy objects in AutoCAD are placeholders for custom objects that are created by ARX applications, such as Autodesk Mechanical Desktop.
By default Proxy objects are displayed if the application that created the custom objects is not currently running. For example, if a drawing that was created in Mechanical Desktop is opened in AutoCAD, objects that can only be created in Mechanical Desktop are displayed as proxy objects.
The following Autodesk applications create proxy objects:
  • Autodesk Mechanical Desktop
  • AutoCAD Mechanical
  • AutoCAD Architectural Desktop
  • AutoCAD Land Development Desktop
Solution
You can perform operations such as moving and copying proxy objects; however, special editing operations unique to the ARX application will not be available in AutoCAD. For example, you cannot perform parametric modifications to Mechanical Desktop objects in any application other than in Mechanical Desktop.
This rule applies whenever an ARX application that created the custom objects is not currently running while the drawing is opened in AutoCAD. The ARX application might be installed on the workstation, but not be running on the workstation.
Maybe WBLOCK belongs to the group of "special editing operations"?
  • 2 weeks later...
