steven-g Posted December 17, 2018 Posted December 17, 2018 I have been struggling for hours to get a selection working in lisp only to find that the problem is in the actual dwg file, but I can't see why! Attached are two dwg's "False" is a collection of lines and "True" is the same collection of lines copied into a new drawing using 0,0 as a base point but this simple line of code will only work in the "True" drawing can anyone see why that should be? It's driving me mad. (command "select" "f" "708.925,-599.75" "708.925,-599.95" "") Even running the select command from the command line with the option "fence" and "end" is failing False.dwg True.dwg Quote
marko_ribar Posted December 17, 2018 Posted December 17, 2018 (edited) Just stab in the dark... Check PICKFIRST sys var... IMHO it should be 1... And also check for QAFLAGS undocumented sys var - env var... Experiment with QAFLAGS... After experimenting return it back to 0 - this is necessity if you want CAD to operate normally... Edited December 17, 2018 by marko_ribar Quote
Grrr Posted December 17, 2018 Posted December 17, 2018 Quote Caution: Only objects visible in the drawing area at the time of selection will be selected by this method. Consider temporarily zooming to the selection window before performing the selection, and then zoom previous to restore the original screen position. Quote from ssget funciton reference (LM) Quote
steven-g Posted December 17, 2018 Author Posted December 17, 2018 Pickfirst=1 QAFLAGS=2 same in both drawings both drawings "zoom" "extents" but one fails? Quote
ronjonp Posted December 17, 2018 Posted December 17, 2018 Strange enough. but when the current vport is set to anything but '2D wireframe' view it fails? Same behavior with SSGET too: (sssetfirst nil (ssget "_F" '((708.925 -599.75)(708.925 -599.95)))) Quote
steven-g Posted December 17, 2018 Author Posted December 17, 2018 Thank you ronjonp it's easy when you know how, it does seem odd behavior that you can't select in this way dependant on display mode, but that certainly solves the problem. Quote
ronjonp Posted December 17, 2018 Posted December 17, 2018 41 minutes ago, steven-g said: Thank you ronjonp it's easy when you know how, it does seem odd behavior that you can't select in this way dependant on display mode, but that certainly solves the problem. It's very odd behavior .. I'd even call it a bug! Quote
