Hi All
Is there a command in Autolisp that allows me to delete all objects on a certain layer?
Did you tried LayDel Command ?
Edited by gS7
Yes I have tried that and of course it works
I guess it was a silly question from the start
FYI, the laydel command would delete all objects on a certain layer name and delete the layer object itself from the drawing, so if you have other objects in the drawing and even in a block then they would be deleted as well.
Finally deleting object(s) on a certain layer does not mean to delete the layer name to delete the object(s) that reside(s) on that layer.
Thanks again
The idea here is that once I have finished using my construction lines I want to hit a command and they will all be deleted
On 12/20/2018 at 4:17 PM, TunzaGibbo said:
Thanks again
you mean you want to delete all  objects from  "construction lines " layer ?
    (setq OB (ssget "x" (LIST (CONS 8 "construction lines" ))))
    (command "Erase" OB "")
I ended up using the "laydel command" and I realized the objects and the layer are deleted. but next time I run my Xline routine I have a little sub-routine that creates the Construction Layer again
Thank you though for that little bit of code I'll store it away for another day
  • 9 months later...
On 12/23/2018 at 9:36 PM, gS7 said:
hi,
I try to wrote a script with script writer to erase a layer, but when I use laydel, it doesn't work.
I wrote this : _open *file* _-laydel _name AFURFR-P   _audit _yes _ai_selall _-overkill _done _-purge r * n _-purge _all * n  _Qsave _close
but the script stop because when it said enter the layer's name,  all the rest of the command appear, like this.
Enter the layer's name : AFURFR-P   _audit _yes _ai_selall _-overkill _done _-purge r * n _-purge _all * n  _Qsave _close
layer's name invalid...
can you help me please.
