Command to rotate
What is the command that is used to rotate the grid at 45 degress?
The grid is aligned with the UCS (User Coordinate System), so if you rotate your UCS, the grid rotates with it.
Command: UCS
Enter Z for the axis you want to rotate around
Enter 45 for the angle
Here's more information on grid and snap: https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/AutoCAD-Core/files/GUID-FEA6BC6E-D81E-4AD2-BD4C-70078C57709A-htm.html
