MURAl_KMD Posted December 26, 2018 Posted December 26, 2018 http://www.lee-mac.com/upgradedburst.html This program is very useful for me. I wish to inform a drawback which i found, this may be helpful to take this program to next level. If a block contains arrayed objects (unexploded array objects), when nburst or pburst used to explode blocks , the arrayed objects are not at original location. Thanks to CADTutor and Lee Mac for helping me to improve my lisp programming skills. Quote
Lee Mac Posted December 26, 2018 Posted December 26, 2018 This is unfortunately a bug with the ActiveX explode method; I shall need to modify the program to test whether the block definition contains nested arrays and if so, revert to using the AutoCAD explode command. Quote
MURAl_KMD Posted December 26, 2018 Author Posted December 26, 2018 Thank you for consideration.... Quote
