Bill Tillman Posted January 11, 2019 Posted January 11, 2019 Sorry to have to revisit this but the new year brought in new problems. I'm working with this dynamic block which I want to insert from a point on the left side of it. That point will remain stationary when the block is stretched and the middle stretches symmetrically at 50%. What I don't see working correctly is the dimension showing the door opening. It too stretches but the text ends up anything but centered on the dimension line. dbldoordynblk.dwg Quote
Adju Posted January 22, 2019 Posted January 22, 2019 I don't know if you find the answer to your question but just removing the dimension from your selection just do the job. I joined a revision of your drawing. dbldoordynblk_Rev.dwg Quote
Adju Posted January 22, 2019 Posted January 22, 2019 "have found" instead of find... Sorry for the bad english... Quote
