johnengineer Posted June 1, 2007 Posted June 1, 2007 Autocad Express Tools allows converting text to mtext. How would I be able to combine multiple mtext into a single mtext? Quote
ReMark Posted June 1, 2007 Posted June 1, 2007 A routine to do just that is included in: ToolPac 11.0 by dotsoft. $245 US. A steep price to pay unless you can make use of the other routines included or you have a great deal of mtext to combine. Quote
Guest Alan Cullen Posted June 1, 2007 Posted June 1, 2007 Have you ever tried Copy/paste?????? It really is very easy......... Quote
johnengineer Posted June 1, 2007 Author Posted June 1, 2007 It would be tedious if the drawing had multiple mtexts. Quote
tzframpton Posted June 1, 2007 Posted June 1, 2007 if the MTEXT are all in line, the EXPLODE to text, then run the TXT2MTXT command. Quote
ChrisCMU Posted February 26, 2008 Posted February 26, 2008 That command works, but they are still stacked into lines. I see you can stretch the text by grabbing the handles and modifying it until it is on one line, but then it has spaces between the former lines. Do you know a way of having it do that automatically, and remove spaces where you want to? Example: 123 456 789 becomes: 123456 789 The space between 3 and 4 removed. Quote
ChrisCMU Posted February 26, 2008 Posted February 26, 2008 it seems like if there was a way to do the mtext ruler without the dialog box that would be the key. but ddedit and mtedit don't seem to work in command line only. Quote
osenmer Posted January 5, 2012 Posted January 5, 2012 this works ( http://cadtips.cadalyst.com/notestext/merge-text-objects ) Quote
