masterfal Posted January 22, 2019 Share Posted January 22, 2019 (edited) Hi Yall, Got this strange issue where when i'm printing dot hatch pattern, it doesn't seem to print out, even though it shows up fine in plot preview. If i export to pdf and print, the hatch looks fine. It just doesn't show up when i print straight from autocad. Don't want to have to always print from pdf though There are other users who can print the same file to the same printer and its all good so thats telling me it must be a setting somewhere, just not sure what it could be Tried adding new plotter with new pc3 file (same printer as previous just with new name/setup) but same thing still happens edit - the hatch prints when i change it to come out black instead of coloured.. need it to be coloured though. and if other machines can print it properly this one should too Edited January 22, 2019 by masterfal Quote Link to comment Share on other sites More sharing options...
Aftertouch Posted January 22, 2019 Share Posted January 22, 2019 Sounds like your CTB file is not set properly. Quote Link to comment Share on other sites More sharing options...
masterfal Posted January 22, 2019 Author Share Posted January 22, 2019 same ctb as other users. just tried copying another user's ctb file onto mine just to double check - same thing still happens it previews + plots to pdf as it should so dont think theres anything wrong with ctb Quote Link to comment Share on other sites More sharing options...
masterfal Posted January 22, 2019 Author Share Posted January 22, 2019 i think i may have worked it out.. my plots seem to be plotting with transparency, even though i have it unticked. i added solid hatch and changed transparency to 50%, which appears shaded when i print - both when plot transparency is ticked and unticked i'm the only one using autocad 2019 here whilst others here are using earlier versions which are working fine would this be a bug in the program? should i contact autodesk support? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted January 22, 2019 Share Posted January 22, 2019 Check the System Variable PLOTTRANSPARENCYOVERRIDE. Quote Link to comment Share on other sites More sharing options...
f700es Posted January 22, 2019 Share Posted January 22, 2019 It might be your printer. Does the PDF print out OK on the printer? I have a similar issue. If I try to print a transparent hatch straight from ACAD it won't print correctly but I can print it to a PDF and then the PDF prints out correct on the same printer. Weird Quote Link to comment Share on other sites More sharing options...
masterfal Posted January 24, 2019 Author Share Posted January 24, 2019 On 1/22/2019 at 7:24 PM, SLW210 said: Check the System Variable PLOTTRANSPARENCYOVERRIDE. thankyou so much! i was thinking was going to have to do a reinstall.. so glad i checked here first. why does autodesk make so many silly variables which are so hard to find.. Quote Link to comment Share on other sites More sharing options...
