I have another question regarding this routine.
This routine works perfect and ends perfect when I press "ESCAPE"
But it won't end when I press "ENTER"
Is there some code I need to the 4th last line?
(defun c:conlob (/ *error* Pt1 Pt2 obline)
  (defun *error* (x)
    (resetoldvar)
    (princ "\n*Cancel*")
  (savevartoold) (constructionlayer)
    (setq Pt1 (getpoint "\nPick First Point:")
          Pt2 (getpoint Pt1 "\nPick Second Point:"))
    (command "_xline" Pt1 Pt2 "")
    (setq obline (entlast))
   (while 1
   (command "_copy" obline "" Pt2 pause (command)))
  (resetoldvar)
Regards
Tony
You may want to look into (exit) or (quit).  A lot of folks are totally against it.
Also
(if (setq pt1 (getpoint "\nPick 1st Point:   "))
Could be added
Edited by David Bethel
Thanks David
I'm not sure what you mean by EXIT & QUIT
I understand those 2 commands, but I don't want to just add either of them in a line because the copy is on going and I might want to do 50 copies of that line and then I want to press "Escape" or "Enter" to exit the program.
I think the (exit) and (quit) need to be added into a WHILE command
In other words let me keep copying until I want to stop and then let me out of this program by hitting either the "Escape" or "Enter" keys
Regards
Tony
You currently have an infinite loop: the expression (while 1 ...) will continue to evaluate indefinitely as 1 will always evaluate to a non-nil value. The only way to exit such a loop is to force a break in evaluation using ESC.
If you wish to exit the program in a standard manner (e.g. using ENTER, SPACE, right-click), then you will need to prompt the user for a point to which the object should be copied (using getpoint), and then test for valid input received before proceeding.
For example:
(while (setq pt1 (getpoint "\nSpecify point <exit>: "))
    (command "_.copy" obline "" "_non" Pt2 "_non pt1)
You may also want to look into using the COPYMODE system variable, as this will avoid the need for a loop entirely.
Thanks Lee
I have replaced the first one with the second and it exits with "ESCAPE" or "ENTER"
I don't know why I was making it so hard but using "xline " then "A" Autocad says "Enter angle of xline (0.00) or [Reference]: I didn't think to just pick 2 points here
  (defun *error* (x)
    (resetoldvar)
   (while 1
  (resetoldvar)
(defun c:conlobl (/ Pt1 Pt2 obline)
   (command "_xline" "A" Pt1 Pt2)
   (while (= (getvar "cmdactive") 1) (vl-cmdf "\\"))
  (resetoldvar)
