hi
I'm running a lisp that set a fixed color to a block member (without the need to open the block). for completely unknown reason I get an error;
error: Automation Error. Key not found
when I select a block to be colored.
I've tried to run the lisp on different systems with different AutoCAD versions but I got the same error.
the lisp developer experience no error. the only difference in our systems is our windows local language.
Please help
Autocad 2017
Autocad Architecture 2018
win 7 & 10
Thanksdvl-19-001_V4.LSP
Edited by samifox
23 minutes ago, rlx said:
do you have layer "San" in your drawing?
Yeah, I think that's it.
So, on line 64 it says
(vla-put-layer y lay)
Replace that by
      (if (tblsearch "LAYER" lay)
