Help To work LISP To filling table cells
Sorry English is not good
Hello all
I have 2 LWPOLYLINES
RED LWPOLYLINE
GREEN LWPOLYLINE
When working, the table does not work as shown on the panel
The message appears
 error: ActiveX Server returned an error: Parameter not optional
I ask you for help
  1. (defun c:POP ( / A acDataRow acHeaderRow acMiddleCenter acTitleRow B pts C COLWIDTH CURSPACE D2 DIS DOC E EL I II LEV LEVI LW N NN NUMCOLUMNS NUMROWS OBJTABLE OUT OUT_P P PL PLL PT1 PTCNTR PTLST PTS ROWHEIGHT S SLIST SSN X1 XY Y Y1 YI Z DIST HH INC LW OUT1 P XY1)
  2. (setq el (CAR(entsel "Select a RED LWPOLYLINE : ")))
  3. (setq lw (CAR(entsel "Select a GREEN LWPOLYLINE : ")))
  4. (setq lev (* 10 27))
  5. (setq inc (getdist "\nSet the increment distance here : "))
  6. (SETQ ht (GETREAL "\n-> Enter text height : "))
  7. (INITGET 7)
  8. (COMMAND "PDMODE" 35)
  9. (COMMAND "PDSIZE" HT)
  10. ;;;(SETQ pt1 (VLAX-3D-POINT (GETPOINT "\n-> Pick point for top left hand of table: ")))
  11.   (setq i 0)
  12.             (repeat (- (fix (vlax-curve-getendparam el)) 1);RED
  13. ;;;                (setq d1 (vlax-curve-getdistatparam el i))
  14.                 (setq d2 (vlax-curve-getdistatparam el (1+ i)))
  15.                 (setq pl (cons(vlax-curve-getpointatdist lw d2) pl));RED
  16.                 (setq i (1+ i))
  17.             );REPEAT
  18. ;;;  (PRINC pl)
  19. (setq pll (mapcar '(lambda ( p ) (trans (list (car p) (cadr p) (cdr (assoc 38 (entget lw)))) lw 0)) (mapcar 'cdr (vl-remove-if  '(lambda ( x ) (/= (car x) 10)) (entget lw)))))
  20. (setq pll (append pl pll))
  21. (setq ptLst(vl-sort
  22.               pll
  23.                 '(lambda(a b)(<(car a)(car b)))))
  24. (setq x1(car(car ptLst)))
  25. (setq y1(cadr(car ptLst)))
  26.   (setq ii 0)
  27. (repeat (length ptLst)
  28.                 (setq dis (- (car(nth ii ptLst)) x1))
  29.                 (setq yi (- (cadr(nth ii ptLst)) y1))
  30.                 (setq levi(/ (+ lev yi) 10))
  31.                 (setq xy(vlax-curve-getpointatdist el dis))
  32.                 (setq out(LIST (CAR xy) (CADR xy) levi))
  33.                 (setq out_p(cons out out_p))
  34.                 (setq ii (1+ ii))
  35.             )
  36.             (setq out_pp(reverse out_p))
  37. ;;;  (PRINC xy)
  38. (entmake
  39.     (list
  40.       '(0 . "POLYLINE")
  41.       '(100 . "AcDbEntity")
  42.       '(100 . "AcDb3dPolyline")
  43.       '(66 . 1)
  44.       '(62 . 1)
  45.       '(10 0.0 0.0 0.0)
  46.       '(70 . 8)
  47.       '(210 0.0 0.0 1.0)
  48.     )
  49.   )
  50. (foreach pt out_pp
  51.     (entmake
  52.       (list
  53.         '(0 . "VERTEX")
  54.         '(100 . "AcDbEntity")
  55.         '(100 . "AcDbVertex")
  56.         '(100 . "AcDb3dPolylineVertex")
  57.         (cons 10 pt)
  58.         '(70 . 32)
  59.       )
  60.     )
  61.   )
  62.   (entmake
  63.     (list
  64.       '(0 . "SEQEND")
  65.       '(100 . "AcDbEntity")
  66.     )
  67.   )
  68.   (command "._Change" (entlast) "" "p" "color" "120" "")
  69.   ;;;;;;;;;;;;;;;;;;;;;;;;;
  70.   (SETQ n 0)
  71.   (setq dist 0)
  72.   (while (setq xy1 (vlax-Curve-GetPointAtDist el dist))
  73.          (setq HH(vlax-curve-getpointatdist lw dist))
  74.          (setq yi (- (cadr HH) y1))
  75.          (setq levi(/ (+ lev yi) 10))
  76.          (setq out1(LIST (CAR xy1) (CADR xy1) levi))
  77.
  78.          ;;add the point to a list
  79.          (SETQ pts (CONS (list  (ITOA(SETQ n (1+ n))) (car out1)(cadr out1)(cadDr out1)) pts))
  80. ;;;         (setq pts(cons out1 pts))
  81.                ;;increment the distance for the next point
  82.               (setq dist (+ dist inc))
  83.               (COMMAND "_.TEXT" out1 ht "0" (ITOA n))
  84.               (COMMAND "_.POINT" out1 "")
  85.
  86.   );while
  87.   (if (/= dist dis)
  88.       (progn
  89.     (SETQ pts (CONS (list  (ITOA(SETQ n (1+ n))) (car out)(cadr out)(cadDr out)) pts))
  90.         (COMMAND "_.TEXT" out ht "0" (ITOA n))
  91.         (COMMAND "_.POINT" out "")
  92. ;;;      (setq pts(cons out pts))
  93.     ))
  94.  (setq ptss(reverse pts))
  95. ;;; (setvar 'osmode 0)
  96.  (setq pAt (getpoint"\nPick table insertion point:"))
  97.  (lstToTable pAt "COORDINATES" ptss)
  98.  (princ)
  99. (vl-load-com)
  100.
  101.   )
  102. ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
  103. (defun lstToTable (insPt ; List Insertion point of Table
  104. title ; String Table Title
  105. cmLst ; List of sublists of Values in Rows
  106. /
  107. accol ;AutoCAD.AcCmColor object
  108. col ; Integer Column Item
  109. rows ; Integer Number of Rows
  110. cols ; Integer Number of Columns
  111. row ; Integer Row Item
  112. sbLst ; List of Values in a Row
  113. atable ; Table Object
  114. strg ; String Item in List
  115. )
  116. (if (not insPt)
  117. (setq insPt (getpoint "\nSelect Insertion Point: ")))
  118. (setq rows (1+ (length cmLst))
  119. cols (apply 'max (mapcar 'length cmLst))
  120. atable (vla_addTable insPt rows cols)
  121. )
  122. ; to prevent display table changes at runtime:
  123. (vla-put-regeneratetablesuppressed atable :vlax-true);supres opening and closing table-block object at each writting to table
  124.  (setq accol (vla-get-truecolor atable))
  125.  (vla-setrgb accol 16 37 66)
  126.  (vla-put-truecolor atable accol)
  127.
  128. ;************************************************************************************
  129. ; Populate Title and set title
  130. (vla-settext atable 0 0 title)
  131.  (vla-setrgb accol 255 161 66)
  132.  (vla-setcellcontentcolor atable 0 0 accol)
  133.  ;(vla-setrgb accol 0 64 255)
  134.   (vla-setrgb accol 20 27 105)
  135. (vla-SetCellBackgroundColor atable 0 0 accol)
  136.  (vla-setrgb accol 82 0 0)
  137. ;************************************************************************************
  138. ; Populate Column Headers and Data Rows
  139. (setq row 1
  140. col 0
  141. )
  142. (foreach sbLst cmLst
  143. (foreach strg sbLst
  144. (vla-settext atable row col strg)
  145.   (vla-setcellalignment atable row col acMiddleCenter)
  146.   (vla-setrgb accol 82 0 0)
  147.   (vla-setcellcontentcolor atable row col accol)
  148.
  149.   (if (> col 0)(progn
  150.  (vla-setcelldatatype atable row col acdouble acUnitDistance)
  151.  (vla-setcellformat atable row col "%lu2%pr2")))
  152.    (vla-setrgb accol  255 245 235)
  153.   (vla-SetCellBackgroundColor atable row col accol)
  154.   (setq col (1+ col))
  155. )
  156. (setq col 0
  157. row (1+ row)))
  158.  (vla-insertrows atable 1 (* txtsize 1.5) 1)
  159.  (setq col 0 row 1)
  160.  (foreach strg (list "PT." "X" "Y" "Z")
  161.     (vla-settext atable row col strg)
  162.   (vla-setcellalignment atable row col acMiddleCenter)
  163.   (vla-setrgb accol 82 0 0)
  164.   (vla-setcellcontentcolor atable row col accol)
  165. (vla-setrgb accol 249 198 182)
  166.    (vla-SetCellBackgroundColor atable row col accol)
  167.    (setq col (1+ col)))
  168.  (vla-setcolumnwidth atable 0 (* (getvar 'textsize) )
  169.  (vla-setrowheight atable 1 (* (getvar 'textsize) 1.5))
  170. ;(vla-recomputetableblock atable :vlax-true) ;on the end display table object changes: Every instance of vla-settext
  171. ; opens table-block object, writes and closes them.Works pretty slow!
  172. (vla-put-regeneratetablesuppressed atable :vlax-false)
  173. (vlax-release-object atable) ;release memory used to create this object
  174.  (vlax-release-object accol)
  175. ))
  176. ; The Create Table Function Accepts 3 Arguments including the
  177. ; Insertion point of the table, the Number of Rows and Number of Columns.
  178. (defun vla_addTable (insPt ; Insertion Point of Table
  179.                         rows        ; Integer Number of Rows in Table
  180.                         cols     ; Integer Number of Columns in Table
  181.                         /
  182.                         atable          ; Table Object
  183.                        )
  184. (setq txtsize (getvar 'textsize);|(variant-value (vla-getvariable
  185.                                   (vla-get-activedocument
  186.                                    (vlax-get-acad-object))
  187.                                   "textsize"))|;;commented
  188.       atable     (vla-addtable (vla-get-block
  189.                                   (vla-get-activelayout
  190.                                    (vla-get-activedocument
  191.                                     (vlax-get-acad-object))))
  192.                                       (vlax-3d-point insPt)
  193.                                  rows
  194.                                  cols
  195.                                  (* txtsize 1.25)
  196.                                  (* txtsize 2)))
  197. atable
  198. )
TEST -2.dwg
test final-FORUM.LSP
Edited by hosneyalaa
you may also learn to use the debug function in the lisp editor
1 don't localize acDataRow   acHeaderRow  acMiddleCenter  acTitleRow  (autocad constants)
2 vla_addTable -> vla-addTable (line 154)
3 add  table must include document space (Mspace in this case)
4 setcolumn width in line 209 was wrong
5 because of that you released you table object to early
(defun c:POP  (/      A      B     pts    C   COLWIDTH CURSPACE
        INC    LW     OUT1   P    XY1)
  (setq el (CAR (entsel "Select a RED LWPOLYLINE : ")))
  (setq lw (CAR (entsel "Select a GREEN LWPOLYLINE : ")))
  (INITGET 7)
  (setq i 0)
  (repeat (- (fix (vlax-curve-getendparam el)) 1) ;RED
    (setq pl (cons (vlax-curve-getpointatdist lw d2) pl))
     ;RED
    (setq i (1+ i))
    )     ;REPEAT
;;;  (PRINC pl)
  (setq pll
  (mapcar
    '(lambda (p)
       (trans
  lw
  0))
    (mapcar
      'cdr
      (vl-remove-if '(lambda (x) (/= (car x) 10)) (entget lw)))))
  (setq ptLst (vl-sort
  pll
  '(lambda (a b) (< (car a) (car b)))))
  (setq x1 (car (car ptLst)))
  (setq y1 (cadr (car ptLst)))
  (setq ii 0)
    (setq dis (- (car (nth ii ptLst)) x1))
    (setq yi (- (cadr (nth ii ptLst)) y1))
    (setq levi (/ (+ lev yi) 10))
    (setq xy (vlax-curve-getpointatdist el dis))
    (setq out (LIST (CAR xy) (CADR xy) levi))
    (setq out_p (cons out out_p))
    (setq ii (1+ ii))
  (setq out_pp (reverse out_p))
;;;  (PRINC xy)
  (entmake
    (list
      '(0 . "POLYLINE")    '(100 . "AcDbEntity")
      '(100
 "AcDb3dPolyline")  '(66 . 1)  '(62 . 1)
      '(10 0.0 0.0 0.0)    '(70 . 8)  '(210 0.0 0.0 1.0))
  (foreach pt  out_pp
    (entmake
      (list
 '(0 . "VERTEX")
 (cons 10 pt)
 '(70 . 32)
  (entmake
    (list
      '(0 . "SEQEND")
  (SETQ n 0)
  (setq dist 0)
    (setq HH (vlax-curve-getpointatdist lw dist))
    (setq out1 (LIST (CAR xy1) (CADR xy1) levi))
    (SETQ pts (CONS (list (ITOA (SETQ n (1+ n)))
     (car out1)
     (cadr out1)
     (cadDr out1))
      pts))
    )     ;while
  (if (/= dist dis)
       (car out)
       (cadr out)
       (cadDr out))
        pts))
  (setq ptss (reverse pts))
  (setq pAt (getpoint "\nPick table insertion point:"))
  (vl-load-com)
      /     accol ;AutoCAD.AcCmColor object
      ActiveDocument
      mSpace
  (if (not insPt) (setq insPt (getpoint "\nSelect Insertion Point: ")))
   (setq ActiveDocument (vla-get-activedocument (vlax-get-acad-object)))
   (setq mSpace(vla-get-modelspace ActiveDocument))
 ;;; * * * edit  vla_addTable : underscore is wrong , added mspace, point format wrong , row height / width missing
 atable (vla-addTable mSpace (vlax-3D-point insPt) rows cols 5 10)
  (setq row 1
 col 0
    (foreach strg  sbLst
      (if (> col 0)
      (setq col (1+ col))
    (setq col 0
   row (1+ row)))
  (setq col 0 row 1)
  ;;;; * * * edit added 1.5 and )
  (vla-setcolumnwidth atable  0 (* (getvar 'textsize) 1.5))
    ) ;;; * * * removed 1 )
        / atable  ; Table Object
                                  "textsize"))|; ;commented
    (vla-get-block
    rows
    cols
    (* txtsize 1.25)
    (* txtsize 2)))
  atable
        INC    LW     OUT1   P    XY1)
  (INITGET 7)
  (setq i 0)
     ;RED
    (setq i (1+ i))
    )     ;REPEAT
;;;  (PRINC pl)
  (setq pll
  (mapcar
    '(lambda (p)
       (trans
  lw
  0))
    (mapcar
      'cdr
  pll
  (setq ii 0)
    (setq ii (1+ ii))
;;;  (PRINC xy)
  (entmake
    (list
      '(100
  (foreach pt  out_pp
    (entmake
      (list
 '(0 . "VERTEX")
 (cons 10 pt)
 '(70 . 32)
  (entmake
    (list
      '(0 . "SEQEND")
  (SETQ n 0)
  (setq dist 0)
     (car out1)
     (cadr out1)
     (cadDr out1))
      pts))
    )     ;while
  (if (/= dist dis)
       (car out)
       (cadr out)
       (cadDr out))
        pts))
  (vl-load-com)
      ActiveDocument
      mSpace
  (setq row 1
 col 0
    (foreach strg  sbLst
      (if (> col 0)
      (setq col (1+ col))
    (setq col 0
   row (1+ row)))
  (setq col 0 row 1)
    (vla-get-block
    rows
    cols
    (* txtsize 1.25)
    (* txtsize 2)))
  atable
Many thanks
The answer to my question
Thanks
