Adler38 Posted January 22, 2009 Posted January 22, 2009 Hello to all. I am fairly new into working with surfaces and exporting to work with my TDS data collector. I know how to make a surface, but the data collector needs to read a .dtm file. This is where I am confused as I have looked and do not see a .dtm extension in Autocad. Also, if anyone does data prep for machine control, I would love to get some advice from you and know where some good training is. Thank you Quote
Hardney Posted January 22, 2009 Posted January 22, 2009 Hi Adler38, first I would need to know what program do you use, because if it is C3D, you are lost because .dtm files were created by Land Desktop. If you are using LDD, well those files are located in the Folder named DTM of the projet folder. For example: [insert project number or name]\DTM\[insert surface name].dtm. Hope this is helpful. Quote
Adler38 Posted January 22, 2009 Author Posted January 22, 2009 I am starting to use Civil 3D, but also have the Civil 3D Land Desktop Companion. I will try to use that to see if that works. Thank you Quote
rustysilo Posted January 22, 2009 Posted January 22, 2009 You might search around on civil3d.com or theswamp.org. I know I've seen info on it somewhere, but have no experience with it. There are guys at theswamp.org who do for sure. Quote
Hardney Posted January 22, 2009 Posted January 22, 2009 Yeah, with the Land Desktop Companion you might find a way to export you surface to a .dtm file, you may check if there nothing for you to do with .xml files, just an idea like this... Good Luck Quote
rustysilo Posted January 22, 2009 Posted January 22, 2009 I've been digging around and found this article. Perhaps it can get you pointed in the right direction. Quote
rustysilo Posted January 22, 2009 Posted January 22, 2009 Or this .dxf to .dtm tool might work. Just get your 3d faces from your model and save them out in their own .dxf file. Then convert. Then again... it doesn't download. Appears their link is bad or the file is no longer available. Quote
User Posted January 22, 2009 Posted January 22, 2009 I've always had luck importing/exporting surfaces using .xml files. Quote
