Pattosun Posted February 12, 2019 Posted February 12, 2019 I would like to batch plot 200 drawings to individual PDFs and for them to save automatically as the original DWG filename, and save to the same folder as the original DWG file... Is this possible? I am a Microstation user boo hiss, haha..... and it is quick and easy to do this with DGNs in Microstation V8i using the Print organiser. I'm sure something similar must be available in AutoCAD but I haven't found it yet. I have tried publishing but it saves the file with the layout name swell so I then have to go through 200 PDFs and rename them.... Any ideas? Thanks in advance, Patto Quote
maratovich Posted February 12, 2019 Posted February 12, 2019 Much depends on how you created the files. Is there a print setting? One layout or more? Best of all attach a sample file or image. There are a lot of solutions, but it depends on the source data. Quote
BIGAL Posted February 12, 2019 Posted February 12, 2019 Like maratovich I have posted previously a plot layout range lisp here that saves the pdf's one level below dwg plotting individual then combining them into 1 pdf. It does rely on the fact that only 1 title block exists this way plot area is known. Its pretty easy to make a lisp that does plot all layouts and combined with a script will plot as many as you need. Need a sample file with title block. Not tested code cut from a plot range pdf ; this is the code to plot a pdf the pdfname variable is pulled from the dwg. Its hardcoded for title size. ; you save it and use it with a script (defun plotpdf ( / dwgpre layouts lay layname) (setq dwgpre (strcat (getvar "dwgprefix") "\pdf")) (SETQ LAYOUTS (vla-get-Layouts (vla-get-activedocument (vlax-get-acad-object)))) (vlax-for lay LAYOUTS (setq layname (vla-get-name lay)) (if (/= layname "Model") (progn (setvar 'ctab layname) (setq pdfname (strcat dwgpre "\\" dwgname "-" layname ".pdf" )) (COMMAND "-PLOT" "Y" "" "dwg to Pdf" "Iso full bleed A3 (420.00 x 297.00 MM)" "m" "LANDSCAPE" "N" "W" "-6,-6" "807,560" "1=2" "C" "y" "Your plotter settings here.ctb" "Y" "n" "n" "n" pdfName "N" "y" ) ) ) ) (princ) ) (plotpdf) script open dwg1 (load "plotpdf") close n open dwg2 (load "plotpdf") close n open dwg3 (load "plotpdf") close n Quote
