Hi, I was wondering if there is a lisp or tool that can create a 'catchment' at any point on a surface.  Currently, using the existing catchment tool command in Civil 3D, you can only create an accurate catchment if it is at the bottom of the slope.  This is because if you use the catchment tool half way down a slope then obviously it won't hold (catch) the water and it will continue to flow downward.
Ultimately I need a tool that upon selecting a point on a surface it creates a polygon that shows where water is getting to that point from.
Thank you.
Is this not like part B of your other post ? Read the reverse of the other post up instead of down.
Admin is this not part B of the same post, there is an answer at the link I provided, just need to go to the top level of the website, there is a download for a lisp that is a start of the solution.
