JoeyG_77 Posted February 26, 2019 Posted February 26, 2019 Hey Guys .... Im trying to load a lisp function from an Icon Ive tried several things but it wont run from the click of the Icon so in saying this .. I need the macro to load the lisp and then invoke the lisp function Thanks for the help in advance Joey G Ps... Ive already pointed my working & trusted folder path to this location on the server where the lisp resides Quote
rlx Posted February 26, 2019 Posted February 26, 2019 just a random buttom from my (old) toolbar (yes yes yes rlxmenu.mns) ID_RLS [_Button("RLSymbols", "rls.bmp", "ICON_16_BLANK")]^C^C(IF (NOT c:rls)(LOAD"RLS.LSP") );RLS does your lisp file actually work? (meaning you are sure it has no errors) do you use a path (backslash \ problems) does your routine start upon loading or do you have to give a command -> like my example (load"rls");rls Best make sure your routines are in your searchpath so no path is needed in your macro. in macro's a space is the same as enter, so is a semicolon ; if your macro has spaces at the end you may not notice them. Maybe you already have a another working button so just copy it and modify it to prevent errors. Think your post is more a general autocad question than a lisp question Quote
JoeyG_77 Posted February 26, 2019 Author Posted February 26, 2019 RLX .... The code you gave me @ the end of your reply worked perfect . I just had to punch in my syntax <^C^C(IF (NOT c:rls)(LOAD"RLS.LSP") );RLS> Thanks for the reply .. Joey G Quote
BIGAL Posted February 27, 2019 Posted February 27, 2019 Not sure if others agree but I just add the (c:rls) to the end of my code this way on 1st load it will run automatically. I have this were I dont have a c:xxx defun but just a defun (rls) with localised variables and the user really only wants to run once. Quote
