Shablab
Count of Polygons crossed with Polyline
Shablab
I have a line that crosses through multiple polygons. Is there a LISP to give me a count of how many polygons this line goes through?
Share this post
Link to post
ronjonp
Here is a quick one .. all objects must be on screen.
(defun c:foo (/ e p s)
  (cond	((and (setq e (car (entsel "\nPick a polyline: ")))
	      (setq p (mapcar 'cdr (vl-remove-if '(lambda (x) (/= 10 (car x)))(entget e))))
	      (setq s (ssget "_F" p))
	 (print (1- (sslength s)))
	 (sssetfirst nil s)
Share this post
Link to post
Shablab
	 (sssetfirst nil s)
That works great.  Is there a way to only select crossed lines only on a selected layer?
Share this post
Link to post
ronjonp
Sure .. change the ssget filter:
(setq s (ssget "_F" p '((0 . "line") (8 . "yourlayer"))))
Edited by ronjonp
Share this post
Link to post
BIGAL
A little bit more
(setq lay (cdr (assoc 8 (entget (car (entsel "pick object for layer"))))))
(setq s (ssget "_F" p (list (cons 0 "line") (cons 8 lay))))
Share this post
Link to post
Shablab
13 hours ago, BIGAL said:
A little bit more
This doesn't seem to be working properly.  It doesn't select any after "pick object for layer".
Edited by Shablab
Share this post
Link to post
BIGAL
There must be some hidden characters in the ssget line, I removed the "f" p and it did not work when I pasted into cad. Re-tested and Ok Retype the line in notepad.
Command: (setq s (ssget "x" (list (cons 0 "Line")(cons 8 lay))))
<Selection set: 55>
(sslength s)
6
Share this post
Link to post
