Dani_Nadir Posted March 1, 2019 Posted March 1, 2019 Hello all, I have this code (defun c:coo () (setvar "cmdecho" 0) (if (not lxg) (setq lxg 100.0)) (if (not lts) (setq lts 2.5)) (if (not llt) (setq llt 10.0)) (setq p nil) (setq p (append p (list (getpoint "\nBottom left corner: ")))) (setq p (append p (list (getpoint (nth 0 p) "\nBottom right corner: ")))) (setq bg (+ (angle (nth 0 p) (nth 1 p)) (/ pi 2))) (setq cp (getpoint (nth 0 p) "\nHeight: ")) (setq dis (distance cp (inters cp (polar cp bg 10.0) (nth 0 p) (nth 1 p) nil))) (setq p (append p (list (polar (nth 1 p) bg dis)))) (setq p (append p (list (polar (nth 0 p) bg dis)))) (setq p (append p (list (nth 0 p)))) (setq abase (getvar "angbase") adir (getvar "angdir")) (setvar "angbase" (/ pi 2)) (setvar "angdir" 1) (setvar "blipmode" 0) (setq xg (getreal (strcat "\nGrid interval <" (rtos lxg 2 0) ">: "))) (if (not xg) (setq xg lxg) (setq lxg xg)) (setq ts (getreal (strcat "\nText height <" (rtos lts 2 2) ">: "))) (if (not ts) (setq ts lts) (setq lts ts)) (setq lt (getreal (strcat "\nTick length <" (rtos llt 2 2) ">: "))) (if (not lt) (setq lt llt) (setq llt lt)) (setq minx (car (nth 0 p)) miny (cadr (nth 0 p)) maxx minx maxy miny) (setq n 1) (repeat 3 (progn (if (< (car (nth n p)) minx) (setq minx (car (nth n p)))) (if (< (cadr (nth n p)) miny) (setq miny (cadr (nth n p)))) (if (> (car (nth n p)) maxx) (setq maxx (car (nth n p)))) (if (> (cadr (nth n p)) maxy) (setq maxy (cadr (nth n p)))) (setq n (1+ n)) ) ) (setq xs (+ xg (* (fix (/ minx xg)) xg)) ys (+ xg (* (fix (/ miny xg)) xg))) ;;;do 'x' grid (bearing = pi/2) (while (<= xs maxx) (setq n 0 plist nil) (repeat 4 ;;;;; find the 2 intersecting grid points with boundary (progn (if (setq ip (inters (list xs miny) (list xs maxy) (nth n p) (nth (1+ n) p))) (setq plist (append plist (list ip))) ) (setq n (1+ n)) ) ) (if (> (cadr (nth 0 plist)) (cadr (nth 1 plist))) (setq p2 (nth 0 plist) p1 (nth 1 plist)) (setq p1 (nth 0 plist) p2 (nth 1 plist)) ) (setq xs (+ xs xg)) ) ;;; end while ;;;do 'y' grid (bearing = 0) (while (<= ys maxy) (setq n 0 plist nil phil "done") (repeat 4 ;;;;; find the 2 intersecting grid points with boundary (progn (if (setq ip (inters (list minx ys) (list maxx ys) (nth n p) (nth (1+ n) p))) (setq plist (append plist (list ip))) ) (setq n (1+ n)) ) ) (if (> (car (nth 0 plist)) (car (nth 1 plist))) (setq p2 (nth 0 plist) p1 (nth 1 plist)) (setq p1 (nth 0 plist) p2 (nth 1 plist)) ) ;;;do '+' grid marks (setq sx (car p1) ex (car p2) fx (+ xg (* (fix (/ sx xg)) xg))) (while (<= fx ex) (setq p0 (list fx ys)) (command "_line" (polar p0 pi (/ lt 2.0)) (polar p0 0.0 (/ lt 2.0)) "") (command "_line" (polar p0 (/ pi 2) (/ lt 2.0)) (polar p0 (* pi 1.5) (/ lt 2.0)) "") (setq fx (+ fx xg)) (command "_text" (polar p0 0 (* ts 3.0)) ts (angtos 0) (strcat "N "(rtos ys 2 0) )) (command "_text" (polar p0 0 (* ts 3.0)) ts (angtos (/ pi 2)) (strcat "E " (rtos ys 2 0) )) ) (setq ys (+ ys xg)) ) ;;; end while (setvar "angbase" abase) (setvar "angdir" adir) (setvar "blipmode" 1) (princ) ) It is to draw grid marks with their respective N and E coordinates. N coordinate are well but E are wrong. And I'd like to center all texts with the grids, as you can see from the dwg. I am really bad at coding I know, but I cant advance. thanks! 1.dwg Quote
ronjonp Posted March 1, 2019 Posted March 1, 2019 Why don't you use an attributed block with fields? Quote
ronjonp Posted March 1, 2019 Posted March 1, 2019 (edited) Attached is an example that took a couple of minutes to create using the standard array command and a custom block. 1.dwg Edited March 1, 2019 by ronjonp *Attached file without EDU stamp Quote
Arshad Mirza Posted April 1, 2019 Posted April 1, 2019 On 3/1/2019 at 8:57 PM, Dani_Nadir said: Hello all, I have this code (defun c:coo () (setvar "cmdecho" 0) (if (not lxg) (setq lxg 100.0)) (if (not lts) (setq lts 2.5)) (if (not llt) (setq llt 10.0)) (setq p nil) (setq p (append p (list (getpoint "\nBottom left corner: ")))) (setq p (append p (list (getpoint (nth 0 p) "\nBottom right corner: ")))) (setq bg (+ (angle (nth 0 p) (nth 1 p)) (/ pi 2))) (setq cp (getpoint (nth 0 p) "\nHeight: ")) (setq dis (distance cp (inters cp (polar cp bg 10.0) (nth 0 p) (nth 1 p) nil))) (setq p (append p (list (polar (nth 1 p) bg dis)))) (setq p (append p (list (polar (nth 0 p) bg dis)))) (setq p (append p (list (nth 0 p)))) (setq abase (getvar "angbase") adir (getvar "angdir")) (setvar "angbase" (/ pi 2)) (setvar "angdir" 1) (setvar "blipmode" 0) (setq xg (getreal (strcat "\nGrid interval <" (rtos lxg 2 0) ">: "))) (if (not xg) (setq xg lxg) (setq lxg xg)) (setq ts (getreal (strcat "\nText height <" (rtos lts 2 2) ">: "))) (if (not ts) (setq ts lts) (setq lts ts)) (setq lt (getreal (strcat "\nTick length <" (rtos llt 2 2) ">: "))) (if (not lt) (setq lt llt) (setq llt lt)) (setq minx (car (nth 0 p)) miny (cadr (nth 0 p)) maxx minx maxy miny) (setq n 1) (repeat 3 (progn (if (< (car (nth n p)) minx) (setq minx (car (nth n p)))) (if (< (cadr (nth n p)) miny) (setq miny (cadr (nth n p)))) (if (> (car (nth n p)) maxx) (setq maxx (car (nth n p)))) (if (> (cadr (nth n p)) maxy) (setq maxy (cadr (nth n p)))) (setq n (1+ n)) ) ) (setq xs (+ xg (* (fix (/ minx xg)) xg)) ys (+ xg (* (fix (/ miny xg)) xg))) ;;;do 'x' grid (bearing = pi/2) (while (<= xs maxx) (setq n 0 plist nil) (repeat 4 ;;;;; find the 2 intersecting grid points with boundary (progn (if (setq ip (inters (list xs miny) (list xs maxy) (nth n p) (nth (1+ n) p))) (setq plist (append plist (list ip))) ) (setq n (1+ n)) ) ) (if (> (cadr (nth 0 plist)) (cadr (nth 1 plist))) (setq p2 (nth 0 plist) p1 (nth 1 plist)) (setq p1 (nth 0 plist) p2 (nth 1 plist)) ) (setq xs (+ xs xg)) ) ;;; end while ;;;do 'y' grid (bearing = 0) (while (<= ys maxy) (setq n 0 plist nil phil "done") (repeat 4 ;;;;; find the 2 intersecting grid points with boundary (progn (if (setq ip (inters (list minx ys) (list maxx ys) (nth n p) (nth (1+ n) p))) (setq plist (append plist (list ip))) ) (setq n (1+ n)) ) ) (if (> (car (nth 0 plist)) (car (nth 1 plist))) (setq p2 (nth 0 plist) p1 (nth 1 plist)) (setq p1 (nth 0 plist) p2 (nth 1 plist)) ) ;;;do '+' grid marks (setq sx (car p1) ex (car p2) fx (+ xg (* (fix (/ sx xg)) xg))) (while (<= fx ex) (setq p0 (list fx ys)) (command "_line" (polar p0 pi (/ lt 2.0)) (polar p0 0.0 (/ lt 2.0)) "") (command "_line" (polar p0 (/ pi 2) (/ lt 2.0)) (polar p0 (* pi 1.5) (/ lt 2.0)) "") (setq fx (+ fx xg)) (command "_text" (polar p0 0 (* ts 3.0)) ts (angtos 0) (strcat "N "(rtos ys 2 0) )) (command "_text" (polar p0 0 (* ts 3.0)) ts (angtos (/ pi 2)) (strcat "E " (rtos ys 2 0) )) ) (setq ys (+ ys xg)) ) ;;; end while (setvar "angbase" abase) (setvar "angdir" adir) (setvar "blipmode" 1) (princ) ) It is to draw grid marks with their respective N and E coordinates. N coordinate are well but E are wrong. And I'd like to center all texts with the grids, as you can see from the dwg. I am really bad at coding I know, but I cant advance. thanks! 1.dwg 40.05 kB · 9 downloads It syas Command: COO Bottom left corner: Bottom right corner: Height: Grid interval <100>: Text height <2.50>: Tick length <10.00>: Error: bad argument type: consp nil pls check what is BAD Quote
