Shablab Posted March 18, 2019 Posted March 18, 2019 I have a bunch of points with Object Data in a drawing and I need that information exported into an Excel file in the format within the Title. At the moment I have been using a workaround by importing and re-exporting and then connecting data with the Task Pane to export to excel file. Is there a lisp to better automate this process? Quote
JuniorNogueira Posted March 18, 2019 Posted March 18, 2019 You can not get the result with the command DATAEXTRACTION ? Quote
Shablab Posted March 19, 2019 Author Posted March 19, 2019 On 3/18/2019 at 10:28 AM, JuniorNogueira said: You can not get the result with the command DATAEXTRACTION ? I did not know about this command and it gets me 85% there. I do not see where to export Object Data with this though. If it's an option within and I'm just missing this then it should give me everything I need. 2 hours ago, harshad said: try this one coor.lsp 8.92 kB · 1 download That Lisp seems to work well but it only exports (X, Y, Z) and doesn't give me an Object Data with the points Quote
Roy_043 Posted March 19, 2019 Posted March 19, 2019 (edited) @Shablab What is meant by 'object data'? Edited March 19, 2019 by Roy_043 Quote
Shablab Posted March 19, 2019 Author Posted March 19, 2019 12 minutes ago, Roy_043 said: @Shablab What is meant by 'object data'? See below. FeatId, OBJECTID, ANCILLARYR, & ENABLED are all associated within Autocad as 'Object Data' (OD). They are just attributes associated with an object given to provide additional information where necessary. You can Mapexport/Mapimport the points with this Data as well. Quote
BIGAL Posted March 20, 2019 Posted March 20, 2019 Search export object data its like attributes just approached in a different way. Quote
