Have You Tried: Watch Your System Variables in AutoCAD
The AutoCAD Blog
Have You Tried
Have you ever noticed the behavior of an AutoCAD command unexpectedly change after using a custom program or script? If so, you aren’t alone.
Some custom programs, while helpful, aren’t always the tidiest of guests in the AutoCAD environment. When some custom programs encounter unexpected errors or are abruptly cancelled, they don’t always restore temporary values of the system variables back to what they were beforehand.
Because of these changes, a command might no longer behave as expected the next time it’s used. To resolve the problem, you might have to spend time researching what happened and then manually change the value of the system variable back to its default or preferred value. Rather than changing the settings manually, you can use the System Variable Monitor to notify you when the value of a system variable is changed and reset the system variable to your preferred value.
Learn more about how to use the System Variable Monitor to watch for unexpected changes to system variables in AutoCAD by following the step-by-step examples in the Have You Tried: Take Control of the Watch Your System Variables topic.
Keep the Feedback Coming
Thanks for all the great feedback submitted so far. Because of the great feedback, we have been able to improve the topics in the AutoCAD Online Help system. Updated Help Topics contains a list of the most recently updated topics.
The best way to submit feedback is by using the “Was this helpful?” section located at the bottom of every Help topic. Let us know what you like or don’t like about a topic or provide suggestions for other subjects that you’d like to see covered in greater detail. The more specific your comments, the better.
The post Have You Tried: Watch Your System Variables in AutoCAD appeared first on AutoCAD Blog.
5KEoLlUhpQI
View the full article
