Hello, I would like to know if it is possible in lisp assign to polyline and lines the layer of the nearest texts?
thanks
 (vl-load-com)
;; ALNT (for Assign Lines Nearest Text)
(defun c:ALNT ( / ss i pt1 pt2 dst lines texts ent tp l txt ind)
  (setq ss (ssget (list (cons 0  "TEXT,LINE,LWPOLYLINE,POLYLINE") ) ))
  (setq
    lines (list)
    texts (list)
  (setq i 0)
  (repeat (sslength ss)
    (setq ent (ssname ss i ))
    (setq tp (cdr (assoc 0 (entget ent))))
    (cond
      ((= tp "TEXT")
        (setq texts (append texts (list ent)))
      ( (or (= tp "LINE") (= tp "LWPOLYLINE") (= tp "POLYLINE"))
        (setq lines (append lines (list ent)))
    (setq i (+ i 1))
  (foreach l lines
    (setq pt1 (cdr (assoc 10 (entget l))))
    (setq
      i 0
      dst nil
    (foreach txt texts
      (setq pt2 (cdr (assoc 10 (entget txt))))
      (if (or (= dst nil) (< (distance pt1 pt2) dst) ) (progn
        (setq dst (distance pt1 pt2))
        (setq ind i)
      (setq i (+ i 1))
    (vla-put-layer
      (vlax-ename->vla-object l)
      (vla-get-layer (vlax-ename->vla-object (nth ind texts)))
thank you very much for your help I will try it
regards
