Rotate specific block to zero degree
acad1985
Hello guys,
I found a lisp on below path,  file to rotate the blocks to 0 degree by the name of the block.but as per this code i need to select the block.
Instead of select the block manually i want to select the block through Lisp. i tried to modify but i can;t able to do that.
Can anyone help me on this.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/rotate-objects-to-0/td-p/5841894
(defun C:B0 (/ bdata sel); = Block to 0 rotation
   ;(setq sel (ssget "_x" '((0 . "INSERT")(2 . "123"))))
  (setq bdata (entget (car (entsel "\nSelect Block for 0 rotation: "))))
    (entmod (subst '(50 . 0) (assoc 50 bdata) bdata))
Thanks in Advance.
Edited by acad1985
Try this :
(vl-load-com)
(defun C:B0 ( / ss cnt)
  (setq ss (ssget "_x" '((0 . "INSERT")(2 . "123"))));123 = Block to rotate to 0
  (repeat (setq cnt (sslength ss))
    (vlax-put-property (vlax-ename->vla-object (ssname ss (setq cnt (1- cnt)))) 'rotation 0)
  );end_repeat
Vanilla. :)
The following would ignore blocks on locked layers.
(defun c:Foo (/ sel int ent get)
  (and (setq int -1 sel (ssget "_X" '((0 . "INSERT"))))
    (while (setq int (1+ int)
                 ent (ssname sel int)
      (setq get (entget ent))
      (if (/= 4
              (logand
                4
                (cdr
                  (assoc 70
                         (entget (tblobjname "LAYER" (cdr (assoc 8 get))))
        (entmod (subst '(50 . 0) (assoc 50 get) get))
Try this
(defun test ( / obj ss bname x)
(setq obj (vlax-ename->vla-object (car (entsel "Pick block for 0"))))
(setq bname (vla-get-EffectiveName obj))
(setq ss (ssget "_x" (list(cons 0  "INSERT")(cons 2 bname))))
(vla-put-rotation (vlax-ename->vla-object (ssname ss (setq x (- x 1)))) 0.0)
(test)
@Tharwat FWIW, there is no need to test for & exclude block references on locked layers, as entmod will simply return nil if the entity is not write-enabled.
Since INSERTs don't require subclass markers, here's another way to perform the entmod:
(defun c:test ( / i s )
    (if (setq s (ssget "_X" '((0 . "INSERT"))))
        (repeat (setq i (sslength s))
            (entmod (list (cons -1 (ssname s (setq i (1- i)))) '(50 . 0.0)))
