how to divide blocks no of blocks in 3d autocad taking coordinates data from Excel using lisp\ VBA
Hi,
i am searching all sites from last 2 days for this i have a 2d autocad drawing with no of blocks in it and they were exploded and added new lines in order to make one dynamic block into no of small blocks now i am having a task to use the coordinates information from 2d drawing to Excel and then i need to split the dynamic block into no of blocks according to Excel and need to insert the block names i.e., main block name and nested block names in side that block.
if anyone can help that will be a great appreciation.
Thanks in advance
I found this go down to Cabs code there is a line
 ;;;          (setq lst (cons name lst)) un remark it
rem this one   (setq lst (cons (cdar (ATT:GETS (vlax-vla-object->ename obj))) lst))
no gurantee and un tested.
Ps took 2 minutes to find. Searched "get nested block names"
Edited by BIGAL
thank you bigal i will search for that thanks once again for guiding me.
