acad1985 Posted April 5, 2019 Posted April 5, 2019 I found a Interesting Routine file to Convert Selected Object bylayer to True Colour. I tried to modify the Lisp for my Drawing but I got Error as below. To change objects' Bylayer colors to their Layers' colors as overrides,; error: Automation Error. Invalid argument color in IAcadEntity::put_Color I want to select all the Object Automatically and convert to Index color. but when i try to run the lisp I got the error. Can someone help me out on this. Quote Quote (defun C:SECLC (/ ss obj ) ;; = Selected Entity Colors to their Layer's Color [if Bylayer] (vl-load-com) (prompt "\nTo change objects' Bylayer colors to their Layers' colors as overrides,") (setq ss (ssget "_X" )) ;(setq ss (ssget)) (repeat (sslength ss) (if (not (assoc 62 (entget (setq ent (ssname ss 0))))); color = Bylayer (progn ; then (setq obj (vlax-ename->vla-object ent)) (vla-put-Color obj (cdr (assoc 62 (tblsearch "layer" (vla-get-Layer obj)))) ); put-color ); progn ); if (ssdel ent ss) ); end repeat ); end defun Thanks in Advance. Quote
rlx Posted April 5, 2019 Posted April 5, 2019 something like this? ;; = Selected Entity Colors to their Layer's Color [if Bylayer] (vl-load-com) (defun c:seclc (/ i ss ent) (prompt "\nChanging objects' Bylayer colors to their Layers' colors as overrides.") (setq i 0) (if (setq ss (ssget "_X")) (while (setq ent (ssname ss i)) (if (not (assoc 62 (entget ent))) (vla-put-color (vlax-ename->vla-object ent) (cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 (entget ent))))))) ) (setq i (1+ i)) ) ) (princ) ) Quote
lido Posted April 6, 2019 Posted April 6, 2019 Try this: (defun vle-color-bylayer->layercolor (/ AcDoc LayerCol ssetObj) (ssget "_X" (quote ((62 . 256)))) (setq AcDoc (vla-get-activedocument (vlax-get-acad-object)) LayerCol (vla-get-layers AcDoc) ssetObj (vla-get-activeselectionset AcDoc) ) (vlax-for Obj ssetObj (vl-catch-all-apply (function vla-put-color) (list Obj (vla-get-color (vla-item LayerCol (vla-get-layer Obj))))) ) (vla-delete ssetObj) (princ) ) Quote
acad1985 Posted April 6, 2019 Author Posted April 6, 2019 Hey Rlx and Lido Thank you so much for your Code, i have checked both of your code, @rlx your code working well as what i want, @lido Thanks for your code, unfortunately this code didn't change anything. Thanks again Quote
lido Posted April 7, 2019 Posted April 7, 2019 Hm... Strange. Please try one more time. I added an counter. (defun vle-color-bylayer->index (/ AcDoc LayerCol n ssetObj) (ssget "_X" (quote ((62 . 256)))) (setq AcDoc (vla-get-activedocument (vlax-get-acad-object)) LayerCol (vla-get-layers AcDoc) n 0 ssetObj (vla-get-activeselectionset AcDoc) ) (vlax-for Obj ssetObj (if (not (vl-catch-all-error-p (vl-catch-all-apply (function vla-put-color) (list Obj (vla-get-color (vla-item LayerCol (vla-get-layer Obj))))))) (setq n (1+ n)) ) ) (vla-delete ssetObj) (prompt (strcat "\n" (itoa n) " found.")) (princ) ) Quote
rlx Posted April 7, 2019 Posted April 7, 2019 (edited) @lido : with colors it's not allways about what's there but also about what's not there : if an entity has a color it has a color code (group 62) , but if entity is color bylayer.....guess what's not there what you want is probably something like this : (defun c:tst ( / AcDoc AcLays)(vl-load-com) (setq AcDoc (vla-get-activedocument (vlax-get-acad-object)) AcLays (vla-get-layers AcDoc)) (vlax-for layout (vla-get-layouts AcDoc) (vlax-for o (vla-get-block layout) (if (eq (vla-get-color o) 256) (vl-catch-all-apply 'vla-put-color (list o (vla-get-color (vla-item AcLays (vla-get-layer o))))))))) Edited April 7, 2019 by rlx Quote
lido Posted April 7, 2019 Posted April 7, 2019 @rlx Yeah, you're right. If the current color is set Bylayer, group code 62 is missing for entities that are drawn to these settings. On the other hand, (ssget "_X" '((62 . 256))) creates a selection set that respects the selection filter but also includes the entities on the locked layers and the function vla-put-color crashes. Trying (ssget "_:L+A" '((62 . 256))) I received nil, so that I used the sequence with vl-catch-all-apply function. Please check your function for the situation where you have locked layers into your drawing. Quote
rlx Posted April 7, 2019 Posted April 7, 2019 @lido if object is on locked layer , function vla-put-layer will error / do nada , but that's where the catch-all-error is for. So I didn't forget , just wasn't in the mood to use is-write-enabled... Quote
