AbdRF Posted April 17, 2019 Posted April 17, 2019 (edited) Hi all, I am working with 2D floorplan and using plain AutoCAD 2019. I am able to connect to the online map using geographic location command in AutoCAD.But I also want latitude and longitude of the certain points in the floorplan with which I have no success till now. Can somebody advise or suggest me how to achieve this? Thanks Edited April 17, 2019 by AbdRF Quote
BIGAL Posted April 23, 2019 Posted April 23, 2019 You will need a co-ord to Lat long program. You need to get a program relevant to your location in the world. Google. Quote
lrm Posted April 23, 2019 Posted April 23, 2019 After setting the geographic location via map or file go to the Geolocation tab and use Mark Position to add position markers to your floor plan. You can then use the list command to give you the latitude/longitude position of the points as well as the WCS coordinates. Command: LIST Select objects: 1 found Select objects: 1 found, 2 total Select objects: POSITIONMARKER Layer: "0" Space: Model space Handle = 221 Latitude: 42.47564509 Longitude: -71.77053900 Elevation: 0.00000000 At Point: X = 29.08230122, Y = 67.19429027, Z = 0.00000000 POSITIONMARKER Layer: "0" Space: Model space Handle = 222 Latitude: 42.47565523 Longitude: -71.77049879 Elevation: 0.00000000 At Point: X = 158.41955278, Y = 113.93650305, Z = 0.00000000 Quote
AbdRF Posted April 25, 2019 Author Posted April 25, 2019 @lrm Thank you very much. I have followed your suggested steps and able to find out Lat and Long. Quote
ap11 Posted September 19, 2020 Posted September 19, 2020 (edited) este lisp sirve para poner la latitud y longitud de un punto indicado (wgs84) indicando el huso y hemisferio (norte o sur) (defun c:latlon (/ out x y ptcoord textloc OLDSNAP OLDBLIP OLDLIGHT ed)(vl-load-com) ;variables as local (setq OLDSNAP (getvar "OSMODE") ;store system variables );setq) (setvar "CMDECHO" 0) ;change system variables (setq smeMa 6378137.0) (setq smeMe 6356752.314) (setq zeta "N") (setvar "OSMODE" 175) (setq PRECISION 14) (setq raiz1 (- (* smeMa smeMa) (* smeMe smeMe))) (setq exd (/ (sqrt raiz1) smeMa)) (setq Sdaexd (/ (sqrt raiz1) smeMe)) (setq SdaeC (* Sdaexd Sdaexd)) (setq rpol (/ (* smeMa smeMa) smeMe)) (initget 128) (while(/= nil (setq out(getpoint (strcat "\nIndique punto ó [HUso<" (rtos PRECISION 2 0) ">/Hemisferio<" ( strcat zeta ) ">]: ")))) (cond ((= 'LIST(type out)) (setvar "OSMODE" 0) (setq x (car out));(rtos (car out) 2 )) (setq y (cadr out));(rtos (cadr out) 2 )) (setq z (caddr out));(rtos (caddr out) 2 )) (setq merC (- (* 6 PRECISION) 183)) (if (= zeta "N") (setq YalEcu y) (setq YalEcu (- y 10000000))) (setq Fiprima (/ YalEcu (* 6366197.724 0.9996))) (setq raiz2 (+ 1 (* SdaeC (* (cos Fiprima) (cos Fiprima))))) (setq Ni (* (/ rpol (sqrt raiz2)) 0.9996 )) (setq aMinusc (/ (- x 500000) Ni)) (setq zTabla (* (/ (* SdaeC (* aMinusc aMinusc)) 2) (* (cos Fiprima) (cos Fiprima)))) (setq Xi (* aMinusc (- 1 (/ zTabla 3)))) (setq sinhXi (/ (- (exp Xi) (exp (- Xi))) 2.0)) (setq seno1 (* 2 Fiprima)) (setq Auno (sin seno1)) (setq Ados (* Auno (* (cos Fiprima) (cos Fiprima)))) (setq Jdos (+ Fiprima (/ Auno 2))) (setq Jcuatro (/ (+ (* 3 Jdos) Ados) 4)) (setq Jseis (/ (+ (* 5 Jcuatro) (* Ados (* (cos Fiprima) (cos Fiprima)))) 3)) (setq Alfa (* 0.75 SdaeC)) (setq Beta (* (/ 5.0 3.0) (* Alfa Alfa))) (setq Gamma (* (/ 35.0 27.0) (* Alfa (* Alfa Alfa)))) (setq Bfi (* (* 0.9996 rpol) (- (+ Fiprima (* Beta Jcuatro)) (+ (* Alfa Jdos)(* Gamma Jseis))))) (setq bMinusc (/ (- YalEcu Bfi) Ni)) (setq Eta (+ (* bMinusc (- 1 zTabla)) Fiprima)) (setq DeltaLamda (atan (/ sinhXi (cos Eta)))) (setq Tau (atan (* (cos DeltaLamda) (/ (sin Eta) (cos Eta))))) (setq Firad (+ Fiprima (* (- (+ 1.00 (* SdaeC (* (cos Fiprima) (cos Fiprima)))) (* (* 1.50 (* SdaeC (sin Fiprima))) (* (cos Fiprima) (- Tau Fiprima)))) (- Tau Fiprima)))) (setq long (+ (* (/ DeltaLamda pi) 180) merC)) (setq lat (* (/ Firad pi) 180)) (princ "\nLatitud: ") (princ (rtos lat 2 12)) (princ "\nLongitud: ") (princ (rtos long 2 12)) (setq angulo3 (* pi (/ 45.0 180.0))) (setq textloc (POLAR out angulo3 10)) (setq ptcoord (strcat "(" (rtos lat 2 8)", " (rtos long 2 ")" )) (setq ptcoordz (strcat "(" (rtos lat 2 ", " (rtos long 2 ")" )) (setq zeta10 ptcoord) (command "_MLEADER" out textloc (strcat zeta10)) (setq sset (entlast)) (vla-put-TextRotation (vlax-ename->vla-object sset) (setq angulo4 (* pi (/ 90 180.0)))) (setvar "OSMODE" 175) ); end condition #1 ((= (strcase out) "HU") (initget 4) (if (setq PRECISION2 (getint (strcat "\nHUso< " (rtos PRECISION) " >: "))) (setq PRECISION PRECISION2) ) ); end condition #2 ((= (strcase out) "H") (initget 1 "S N") (if (setq zeta2 (getkword (strcat "\Hemisferio [Norte/Sur]:"))) (setq zeta zeta2) ) ); end condition #5 (T (alert "Opción no valida!") ); end condition #6 ); end cond (initget 128) ); end of while (princ) ) Edited September 19, 2020 by ap11 error ortográfico Quote
