In my lisp, I'm trying to input the paper size from my plotter... 18"x24" (ARCH C)
It keeps taking the " mark after the 18 as an input
When I change it to 18\"x24\" (ARCH C) it gives me the same problem.
Any other suggestions on how to be able to use the inch mark in my lisp?
Thank you
Escaping the double-quotes using a single backslash escape character will cause the double-quotes to appear in the string (as opposed to being interpreted as string delimiters). Hence, you should use:
"18\"x24\" (ARCH C)"
Edited by Lee Mac
Thanks Lee...  I did have the " before and after.  It's still hanging up.
What about the Chr 34 string.  Would it work for this?
This is what I need to get enter "18"x24" (ARCH C)" but it doesn't like the " after 18 and after 24
In your example above you're missing the outer quotes: "18\"x24\" (ARCH C)"
(chr 34) is the same as an escaped double-quote - observe:
_$ (= (chr 34) "\"")
T
Are you using strcat or trying to write as implied which doesnt work.
