prax3des Posted May 8, 2019 Share Posted May 8, 2019 Hello, I need to increase the resolution of this plane, especially the 3d view print in pdf with good quality. (The PDF example is my problem) Thank Formato_valvula.dwg example.pdf Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 8, 2019 Share Posted May 8, 2019 What are you using to print the pdf? I opened your file and printed using the standard DwgtoPdf plotter and mine looks quite a bit better than your's. It's still not great, but it's better. Disclaimer: To be clear, I am using 2018, not 2015, so my pdf plotter may produce better quality images than your's. For a better result, what I would do is render the 3D valve and save the rendered image to .png or .tif format. Then insert the rendered image in place of the 3D model. Quote Link to comment Share on other sites More sharing options...
SEANT Posted May 9, 2019 Share Posted May 9, 2019 19 hours ago, prax3des said: Hello, I need to increase the resolution of this plane, especially the 3d view print in pdf with good quality. (The PDF example is my problem) Thank Formato_valvula.dwg 2.28 MB · 5 downloads example.pdf 29.02 kB · 8 downloads VIEWSTD command will provide means for upping the view quality (Shaded view quality). I maxed it out to produce the attached. Formato_valvula_300DPI.pdf 1 Quote Link to comment Share on other sites More sharing options...
Cad64 Posted May 9, 2019 Share Posted May 9, 2019 Good call. I wasn't aware of that command. Apparently it's only available on 64 bit systems though, so if you're running a 32 bit system, you're out of luck. https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/AutoCAD-Core/files/GUID-2650ABC3-F838-4911-A19C-C4EC1396DD3D-htm.html Quote Link to comment Share on other sites More sharing options...
SEANT Posted May 9, 2019 Share Posted May 9, 2019 Damn, That's pretty harsh on our bit-deficient brethren. Quote Link to comment Share on other sites More sharing options...
