notredave Posted May 8, 2019 Posted May 8, 2019 Good afternoon, Can somebody be so kind to modify an Asmi lisp routine (attached) to automatically adjust the break distance based on dimscale factor of drawing? It is defaulted to 1/8". Also, there are times when I hit ctrl+c to cancel lisp, I lose what my osmode was set to. I have to check all the osnaps I want again. Can this be included in this lisp routine not to lose my osnaps? Thank you very much in advance, David Bri.lsp Quote
dlanorh Posted May 8, 2019 Posted May 8, 2019 (edited) 3 hours ago, notredave said: Also, there are times when I hit ctrl+c to cancel lisp, I lose what my osmode was set to. That's probably because you are hitting Ctrl+C to cancel the lisp, otherwise the lisp will reset the osnap settings. After setting the break distance; on every select option after that, the prompt states "Select ... object or right click to exit". Use this instead of Ctrl+C Edited May 8, 2019 by dlanorh Quote
