jim78b Posted May 16, 2019 Posted May 16, 2019 I have various files in which I think the anonymous block editing function is not enabled, could you modify them? can i attach? Quote
Tharwat Posted May 16, 2019 Posted May 16, 2019 Try to rename it with THIS PROGRAM then you would be able to modify it I believe. Quote
tombu Posted May 16, 2019 Posted May 16, 2019 Tharwat's program with the dialog box looks slicker, but here's an oldie that I got by with for many years: ;=============================================== ; UnAnon.Lsp http://www.davidbethel.com/lisp/ Jul 05, 1998 ;====================================== (princ "\nCopyright (C) 1998, David Bethel owner of Fabricated Designs, Inc.") (princ "\nLoading UnAnon v1.0 ") (setq uan_ nil lsp_file "UnAnon") ;================== For Automated Calling From Another Program ========= (defun uan_auto (ar1) (UnAnon ar1)) ;================== Macros ============================================= (defun PDot ()(princ ".")) (PDot);++++++++++++ Set Modes & Error ++++++++++++++++++++++++++++++++++ (defun uan_smd () (SetUndo) (setq olderr *error* *error* (lambda (e) (and (/= e "quit / exit abort") (princ (strcat "\nError: *** " e " *** "))) (command-s "_.UNDO" "_END" "_.U") (uan_rmd)) uan_var '( ("CMDECHO" . 0) ("MENUECHO" . 0) ("MENUCTL" . 0) ("MACROTRACE" . 0) ("OSMODE" . 0) ("SORTENTS" . 119)("MODEMACRO" . ".") ("BLIPMODE" . 0) ("EXPERT" . 0) ("SNAPMODE" . 1) ("PLINEWID" . 0.0) ("ORTHOMODE" . 1) ("GRIDMODE" . 0) ("ELEVATION" . 0) ("THICKNESS" . 0) ("FILEDIA" . 0) ("FILLMODE" . 0) ("SPLFRAME" . 0) ("UNITMODE" . 0) ("TEXTEVAL" . 0) ("ATTDIA" . 0) ("AFLAGS" . 0) ("ATTREQ" . 1) ("ATTMODE" . 1) ("UCSICON" . 1) ("HIGHLIGHT" . 1) ("REGENMODE" . 1) ("COORDS" . 2) ("DRAGMODE" . 2) ("DIMZIN" . 1) ("PDMODE" . 0) ("CECOLOR" . "BYLAYER") ("CELTYPE" . "BYLAYER"))) (foreach v uan_var (setq m_v (cons (getvar (car v)) m_v) m_n (cons (car v) m_n)) (setvar (car v) (cdr v))) (princ (strcat (getvar "PLATFORM") " Release " (substr (ver) 18 2) " - Convert To Anonymous Blocks ....\n")) (princ)) (PDot);++++++++++++ Return Modes & Error +++++++++++++++++++++++++++++++ (defun uan_rmd () (setq *error* olderr) (mapcar 'setvar m_n m_v) (command-s "_.UNDO" "_END") (prin1)) (PDot);++++++++++++ Set And Start An Undo Group ++++++++++++++++++++++++ (defun SetUndo () (and (zerop (getvar "UNDOCTL")) (command-s "_.UNDO" "_ALL")) (and (= (logand (getvar "UNDOCTL") 2) 2) (command-s "_.UNDO" "_CONTROL" "_ALL")) (and (= (logand (getvar "UNDOCTL") 8) 8) (command-s "_.UNDO" "_END")) (command-s "_.UNDO" "_GROUP")) (PDot);++++++++++++ Get Entity Name ++++++++++++++++++++++++++++++++++++ (defun GetOne (/ st os) (setq os (getvar "SNAPMODE") s nil) (setvar "SNAPMODE" 0) (while (not st) (setq st (ssget))) (while (> (sslength st) 1) (setq st nil) (princ "\nOnly 1 At A Time Please\n") (while (not st) (setq st (ssget)))) (setvar "SNAPMODE" os) (setq s (ssname st 0))) (PDot);++++++++++++ Convert An Anonymous Block To Named Block ++++++++++ (defun UnAnon (b / tdef en ed bc bn bd in) ;Supply ename (setq bn "TEMP1" bc 1) (while (tblsearch "BLOCK" bn) (setq bc (1+ bc) bn (strcat "TEMP" (itoa bc)))) (and (= (type b) 'ENAME) (setq bd (entget b) in (cdr (assoc 2 bd)))) (if (or (not bd) (not in) (/= "INSERT" (cdr (assoc 0 bd))) (/= "*U" (substr in 1 2)) (= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 4) 4) (= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 16) 16) (= (logand (cdr (assoc 70 (tblsearch "BLOCK" in))) 32) 32)) (progn (princ "*** Not An Anonomymous Block *** ") (setq bn nil bc nil bd nil in nil b nil) (exit))) (setq tdef (tblsearch "BLOCK" in) en (cdr (assoc -2 tdef)) ed (entget en)) (entmake (list (cons 0 "BLOCK") (cons 2 bn) (cons 70 0) (cons 10 (cdr (assoc 10 tdef))))) (entmake ed) (while (setq en (entnext en)) (setq ed (entget en)) (entmake ed)) (entmake (list (cons 0 "ENDBLK"))) (setq bd (subst (cons 2 bn) (assoc 2 bd) bd)) (entmod bd) (entupd b) (princ (strcat "\n" bn))) (PDot);************ Main Program *************************************** (defun uan_ (/ m_v m_n olderr uan_var s) (uan_smd) (GetOne) (UnAnon s) (uan_rmd)) (defun c:UnAnonall (/ ss i) (setq ss (ssget "X" (list (cons 0 "INSERT")(cons 67 (if (= (getvar "TILEMODE") 1) 0 1))))) (and ss (setq i (sslength ss)) (while (not (minusp (setq i (1- i)))) (setq en (ssname ss i)) (if (= "*U" (substr (cdr (assoc 2 (entget en))) 1 2)) (UnAnon en)))) (prin1)) (PDot);************ Load Program *************************************** (defun C:UnAnon () (uan_)) (if uan_ (princ "\nUnAnon Loaded\n")) (prin1) ;================== End Program ======================================== I used to get a lot of these from Autoturn generated Vehicle Paths, but haven't seen any since switching to AutoCAD's Vehicle Tracking so I haven't had a chance to test Tharwat's program on one. Let us know how it works. Quote
Roy_043 Posted May 16, 2019 Posted May 16, 2019 In BricsCAD can you use vla-put-name to rename an anonymous block definition. Apparently this is not possible in AutoCAD. Quote
