NoroZorro Posted May 28, 2019 Posted May 28, 2019 Hello forum!!! Need help. I have a block in drawing A,which I want to copy to another drawing. Scale factor of that block is x,y,z 0.0047.That block is in drawing space.Units of both drawing is in mm.When pasting that block into drawing B paper space, it looks much bigger comparing to paper.Scale factor is maintained to 0.0047. drawing B was purged. merci tools.dwg Quote
CyberAngel Posted May 28, 2019 Posted May 28, 2019 In the destination file (the one you're pasting into), check your insertion units. Use the UNITS or DDUNITS command. Under "Insertion Scale" you'll see "units to scale inserted content." That setting will override the scale of the block itself. If that scale is millimeters, you'll have to keep looking. You can also set the global insertion scale with the INSUNITS command/variable. A value of 0 (zero) will make it unitless, so you won't have to worry about relative scales. A value of 4 will set it to millimeters. Another option is the -DWGUNITS command (don't forget the dash), which is a text version of UNITS. It will specifically ask if you want to scale inserted items. Saying No here is just another way to set INSUNITS to zero. And here's a bonus complication from Autodesk. There is a variable named INSUNITSDEFSOURCE that overrides the units for whatever item you get from your source drawing. The default value is 1 (inches). As you might expect, there is a corresponding variable named INSUNITSDEFTARGET that overrides the units in the target drawing, also with default 1. This is a great idea if you're moving metric items into an imperial drawing or vice versa. It's not so great if one of them changes arbitrarily, the way variables do. Check those values, make sure they match your drawings and/or each other. As always, it's a good idea to Purge, Audit, and remove unreferenced XRefs when there's a problem. If all else fails, you might XRef the block into your drawing, correct the scale, and NCOPY it into your destination. It's a last resort because you can only copy the components of the block, one at a time, which you'd have to rebuild as a block. Quote
eldon Posted May 28, 2019 Posted May 28, 2019 I think that your problem is with units. The drawing that you posted is not in metric units. It was based on an imperial units template, which is shown by the System variable MEASUREMENT being 0. Also the plot scale of your paper space is 1mm to 0.03937 drawing units, which is the conversion from imperial units to metric. Be consistent with your units and templates, and you will have less bother. Quote
NoroZorro Posted May 28, 2019 Author Posted May 28, 2019 58 minutes ago, eldon said: I think that your problem is with units. The drawing that you posted is not in metric units. It was based on an imperial units template, which is shown by the System variable MEASUREMENT being 0. Also the plot scale of your paper space is 1mm to 0.03937 drawing units, which is the conversion from imperial units to metric. Be consistent with your units and templates, and you will have less bother. Thank you for your analysis! Quote
BIGAL Posted May 29, 2019 Posted May 29, 2019 You will find that the scale factor problem is 1/0.3048 this is feet to metric have seen it myself. Like the others its to do with original dwg units and new dwg units. Quote
NoroZorro Posted May 29, 2019 Author Posted May 29, 2019 Thanks Guru....from now on i'm using acadiso.dwt Quote
