jim78b Posted May 29, 2019 Posted May 29, 2019 i nedd a lisp to set nested blocks to LAYER 0 COLOR: byblock LINETYPE: preserve the linetype of the layer who was originally is it possible? because layer 0 had continuos line and the layers in nested blocks are different linetypes... i have this code but cheange all originally linetype because they are on different layers (vl-load-com) (defun c:BB0 (/ col cnt lop sel) ;;;--------------------------------------------------------------------------------------------------------------------- ; Dynamic blocks don't update and I dont know why. Vla-update doesnt work. Vla-resetBlock works but all dynamic parametres are lost. ;;; subroutines ;; remove duplicated items in list (defun LM:unique (l) ; by Lee Mac (if l (cons (car l) (LM:Unique (vl-remove (car l) (cdr l)))))) ;; set "by block" to all entities in block definition (defun BB0:setByBlock (nam / blc blk) (setq blc (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object)))) (setq blk (vla-item blc nam)) (vlax-for x blk (vla-put-layer x "0") (vla-put-color x acByBlock) (vla-put-linetype x "ByBlock") (vla-put-linetypescale x 1.0) ;;; (vla-put-lineweight x acLnWtByLayer) ;;; (vla-put-entityTransparency x "ByBlock:") ;;; (vla-put-material x "ByBlock") (if (eq (vla-get-objectName x) "AcDbBlockReference") (BB0:setByBlock (vla-get-effectiveName x)))) ) ;;;--------------------------------------------------------------------------------------------------------------------- ;;; main (setq lop t) (while lop (princ "\nSelect blocks: ") (if (setq sel (ssget '((0 . "INSERT")))) (progn (setq cnt 0) (setq col nil) (repeat (sslength sel) (setq obx (vlax-ename->vla-object (ssname sel cnt))) (setq col (cons (vla-get-effectiveName obx) col)) (setq cnt (1+ cnt))) (setq col (LM:unique col)) (foreach x col (BB0:setByBlock x)) (setq lop nil)) (princ "\nNo selection"))) (vla-regen (vla-get-ActiveDocument (vlax-get-acad-object)) acActiveViewport) (princ)) Quote
jim78b Posted May 29, 2019 Author Posted May 29, 2019 thanks you are so kind , i found a lisp that works! ;; BN.lsp [command name the same] ;; = change all Block Entities [other than on Layer Defpoints] in selected Blocks' ;; definitions, including in any Nested Blocks, to Layer 0 with Color & Linetype ;; overrides from entity's source layer properties [if not otherwise overridden] ;; Kent Cooper, last edited 4 November 2014 (vl-load-com) (defun C:BN0 (/ *error* nametolist doc blkss inc blokobj blkname blknames ent edata ldata) (defun *error* (errmsg) (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break")) (princ (strcat "\nError: " errmsg)) ); if (vla-endundomark doc) (princ) ); defun - *error* (defun nametolist (blk / blkobj blkname); get Block name and put it into list of names (if (= (logand (cdr (assoc 70 (entget blk))) 4) 0) ; not an Xref (progn (setq blkobj (vlax-ename->vla-object blk) blkname (vlax-get-property blkobj (if (vlax-property-available-p blkobj 'EffectiveName) 'EffectiveName 'Name) ; to work with older versions that don't have dynamic Blocks ); ...get-property & blkname ); setq (if (not (member blkname blknames)); name not already in list (setq blknames (append blknames (list blkname))); then -- add to end of list ); if ); progn ); if ); defun -- nametolist (setq doc (vla-get-activedocument (vlax-get-acad-object))) (vla-startundomark doc); = Undo Begin (if (setq blkss (ssget '((0 . "INSERT")))); User selection of any number of Blocks/Minserts/Xrefs (progn; then (repeat (setq inc (sslength blkss)); list of Block names from top-level selection (nametolist (ssname blkss (setq inc (1- inc)))) ); repeat (while (setq blk (car blknames)); as long as there's another Block name in list ;; [this way instead of via (repeat) or (foreach), so it can add Nested Blocks' names to list] (setq ent (tblobjname "block" blk)); Block definition as entity (if (= (logand (cdr (assoc 70 (entget ent))) 4) 0) ; not an Xref (while (setq ent (entnext ent)); then -- proceed through sub-entities in definition (setq edata (entget ent)) (if (member '(0 . "INSERT") edata) (nametolist ent)); if nested Block, add name to end of list (if (not (member '(8 . "Defpoints") edata)); process all entities NOT on Layer Defpoints (progn ; then (setq ldata (entget (tblobjname "layer" (cdr (assoc 8 edata))))); entity's Layer's properties (if (or ; [no Color override] (not (assoc 62 edata)); Bylayer (member '(62 . 0) edata); Byblock ); or (setq edata (append edata (list (assoc 62 ldata)))); then -- assign Layer's color ); if (if (and (or ; [no Linetype override] (not (assoc 6 edata)); Bylayer (member '(6 . "ByBlock") edata) ); or (not (member '(6 . "Continuous") ldata)) ; don't override ByLayer/ByBlock with Layer's linetype if Continuous ); and (setq edata (append edata (list (assoc 6 ldata)))); then -- assign Layer's linetype ); if (setq edata (subst '(8 . "0") (assoc 8 edata) edata)); to Layer 0 (entmod edata) ); progn -- then ); if -- not on Defpoints ); while -- sub-entities ); if (setq blknames (cdr blknames)); take first Block name off list ); while (command "_.regen") ); progn (prompt "\nNo Block(s) selected."); else ); if [user selection] (vla-endundomark doc); = Undo End (princ) ); defun (prompt "\nType BENL0CL to change all selected Blocks' Entities to Layer 0 retaining their Layers' color/linetype.") Quote
ronjonp Posted May 29, 2019 Posted May 29, 2019 (edited) @jim78b When posting code please use the code tags: GIF posted below for some reason.. Edited May 29, 2019 by ronjonp Quote
ronjonp Posted May 29, 2019 Posted May 29, 2019 1 minute ago, jim78b said: oh sorry excuse me No need to be sorry .. just trying to teach you something new Quote
ronjonp Posted May 29, 2019 Posted May 29, 2019 5 minutes ago, jim78b said: yes ! now i know! Glad to help Quote
jim78b Posted May 30, 2019 Author Posted May 30, 2019 can you modify it so that with double command I can also modify the elements that are not in the blocks? please Quote
