Ross Dunkley Posted June 4, 2019 Posted June 4, 2019 Hi, I am running into problems with my program when I try to use the output from the "LM:directoryfiles" function. If I try to use the output from the "LM:directoryfiles" function (findjgw) I am getting the following error... error: bad argument type: (or stringp symbolp): ("L:\\DESIGN\\2018\\2018-290 Atkinson Crescent, ALDINGA BEACH\\Work in Progress CAD\\References CAD\\2018-290 Image\\2018-290 Image.jgw") (findjgw) returns the following "L:\\DESIGN\\2018\\2018-290 Atkinson Crescent, ALDINGA BEACH\\Work in Progress CAD\\References CAD\\2018-290 Image\\2018-290 Image.jgw" and if I enter this actual text string in my code it works, but it wont when referring to the variable (findjgw). Is it because I am trying to use a list as a string? If I only use the first element of a list are they not the same thing? Snippet that seems to be thew problem... ; Search Project "References CAD" Folder for ".jgw" files and Count how many... (setq rcpath (strcat sfpath "Work in Progress CAD\\References CAD\\")) (setq findjgw (LM:directoryfiles rcpath "*.jgw" T)) (setq countjgw (length findjgw)) (cond ( (= countjgw 1) (princ "\nOnly 1 Georeferenced Aerial Image exists in 'References CAD folder'") (setq jpgname (vl-string-subst "jpg" "jgw" findjgw)) (setq intFileDia (getvar "filedia")) (setvar "filedia" 0) (command "mapiinsert" jpgname "") (command "zoom" "e") (setvar "filedia" intFileDia) (princ "\nGeoreferenced Aerial Imagery Inserted...") ) ( (> countjgw 1) (alert "More than 1 Georeferenced Aerial Image exists in 'References CAD folder'...\nPlease select file to insert...") (command "mapiinsert") (princ) ) (t nil) );End Cond I will attach the full copy also. Regards, Ross. ONK Mapiinsert 4.lsp Quote
Emmanuel Delay Posted June 4, 2019 Posted June 4, 2019 First impression: the problem is here: findjgw is a list, (vl-string-subst expects a string there. (setq jpgname (vl-string-subst "jpg" "jgw" findjgw)) This should work: (setq jpgname (vl-string-subst "jpg" "jgw" (nth 0 findjgw ))) 1 Quote
ronjonp Posted June 4, 2019 Posted June 4, 2019 One thing I see that could cause an issue is 11 hours ago, Ross Dunkley said: Is it because I am trying to use a list as a string? If I only use the first element of a list are they not the same thing? Yes .. you cannot pass a list to vl-string-subst. Use (car findjgw). Also your UNC path check could be simplified to this: (if (wcmatch (getvar 'dwgprefix) "\\*") "UNC" "MAPPED" ) Just guessing, but this looks like an incorrect path too. (setq sfpath (strcat "\\\\" drive "\\" dir1 "\\" dir2 "\\" dir3 "\\" dir4 "\\")) 1 Quote
Ross Dunkley Posted June 5, 2019 Author Posted June 5, 2019 Thanks guys! The following line did the trick... (setq jpgname (vl-string-subst "jpg" "jgw" (car findjgw))) Quote
