BigMikeLV Posted January 26, 2009 Posted January 26, 2009 When you hover over a location defined in your surface and stations you get a pop-up that states you Station, location and your spot elevation. How do I turn this back on? I lost it and I'm sure someone turned it off. Is it a Setvar or is it in a dialog box somewhere? Quote
lpseifert Posted January 26, 2009 Posted January 26, 2009 In Prospector select your Alignment (or surface...) rt-clk > Properties > Information > Show Tooltips check box Quote
BigMikeLV Posted January 26, 2009 Author Posted January 26, 2009 the alignment is still there, all 4 of them. So is the Surface. Quote
lpseifert Posted January 26, 2009 Posted January 26, 2009 Maybe they're turned off globally, try this Settings > Rt-clk on drawing name > Edit drawing settings > Ambient Settings > expand General > Show Tooltips > yes Quote
rustysilo Posted January 26, 2009 Posted January 26, 2009 And if that works, LOCK IT in the ON position. :wink: Quote
