Please help... for some reason, my scroll bar WHEEL of the mouse will not function as a pan all of a sudden. How can I fix this? MUCH appreciated!
Edited by MAREBER
Scroll bar of the mouse? I assume you're talking about the scroll wheel?
What mouse are you using? If it's a Logitech mouse, you may need to reinstall or update the mouse software. This happens to me from time to time.
Yes, the wheel. And yes, it is a Logitech. I have had this for so long that I don't remember it even coming with software?
Thank you, I am trying that now.
Unfortunately, that didn't help at all. I can't find an option to make my scroll wheel act as a pan anywhere???
I use Logitech mice without the SetPoint software. It can cause some minor issues if not set-up properly. I would uninstall it and make sure MBbuttonPan is set to 1.
Yeah, I had trouble setting my mouse wheel to pan also. I ended up setting one of the thumb buttons on the side to pan. It was a little awkward at first, but now I'm used to it. When this mouse dies, I'll probably look for a different brand. I like the mouse, but the pan issue is a little irritating.
Alright, everything is now uninstalled. The MButtonPan was set to 1, but I reentered 1, but that didn't change anything. OMGosh, this is annoying! I've closed and reopened CAD, tried a new mouse... and nothing helps. What happened?
Edited by MAREBER
Even with a different mouse it's still happening? That's kind of weird. When did this start happening? Was it doing this when you opened Autocad this morning or were you working and then all of a sudden pan stopped functioning?
If it was me, I would reinstall set point and set one of the buttons for pan, but if you want your scroll wheel to pan, I'm not sure what to tell you. I don't know why it stopped working?
Here are some suggestions from Autodesk: https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Wheel-button-on-mouse-does-not-perform-zoom-functions.html
It started when I opened CAD this morning. It was working fine when I closed CAD yesterday late afternoon. That is why I closed and reopened CAD, thinking it was just a program glitch. I even tried opening up other drawings to see if it was just this one I am working on, and it is a program wide issue, not just a file issue. I'm sure that I must have done something... but don't know how to UNdo it.
I'll take a look at the suggestions... thank you.
I rebooted and then sort of beat up on my mouse and it is working now- go figure! Thank you any way for the help!
