Seneb Posted January 26, 2009 Posted January 26, 2009 When printing a set through the Sheet Set Manager at 30x42, it results in errors and doesn't output the PDF. I have checked the pc3 file for proper page sizes, and all the settings look good. The pages print to PDF individually without a problem, but individually printing 20+ pages is highly annoying. The only work-around I have found is to plot the pages to DWF, open them in Design Review, and print from there to PDF. Any ideas? Quote
chelsea1307 Posted January 28, 2009 Posted January 28, 2009 have you tried publishing them to pdf instead of using sheet set? make sure you have pagesetups for the pdf then type publish add all the layouts you want published and hit publish. works well for me Quote
Seneb Posted January 28, 2009 Author Posted January 28, 2009 With your project loaded in the Sheet Set Manager (SSM): Right-click on a sheet Click “Publish” Click “Manage Page Setups…” In the Page Setup Manager, click “New…” In the New Page Setup dialog, type: “42x30 PDF Horizontal” (This is what we use in the office so it shows up horizontal in Adobe) Click OK to continue. In Page Setup, the fields are as follows: Page Setup: 42x30 PDF Horizontal Plot Style Table: WhateverFileYouUse.ctb Printer/Plotter: DWG to PDF.pc3 Shaded Viewport Options: n/a Paper Size: ARCH E1-L (42.00 x 30.00 Inches) Plot Options: “Plot with styles” & “Plot paperspace last” should be checked Plot Area: Layout Plot Scale: 1:1 Plot Offset: X: -0.5 & Y: 0.0 (This one you might have to play with. These settings worked for us) When finished, click OK to continue. The Page Setup Manager should show the new setup at the top of the list. Click Close to continue. You now need to select which files you want to plot within the SSM. If you want to print all files for one section, then simply right click on the section heading. For multiple files within the heading, hold down the “Ctrl” button on the keyboard and left-click to select which individual files you want to plot. With the files selected, right-click on any of the selections… Click “Publish” Click “Publish using Page Setup Override” Click “42x30 PDF Horizontal” NOTES: By default, the pages will be sent to your “My Documents” folder on your computer. To change this, right-click on the main SSM heading, click Publish, and click Sheet Set Publish Options. In the top field (Default output location) you can direct where AutoCAD will place the files for that project. Depending on your AutoCAD settings, the pages will be either in one PDF or individual PDFs. To check or change your settings, type “PUBLISHCOLLATE” in the Command Line. A setting of 0 will result in the PDFs printing as individual files. A setting of 1 will result in an output of one PDF file with all pages within. Quote
chelsea1307 Posted January 28, 2009 Posted January 28, 2009 glad you figured it out. Thanks for the note on PUBLISHCOLLATE ive been trying to figure that out for a while. Quote
