johnengineer Posted January 27, 2009 Posted January 27, 2009 I would like to create a macro using the "change" command. I would like to have it change the objects I select to bylayer color. How can I achieve this with the control characters used in macros? Quote
CarlB Posted January 27, 2009 Posted January 27, 2009 ^C^CSELECT\CHPROP;P;;C;;; The select at the beginning allows user to select using various methods. The "chprop" command then calls the "previous" selection, changes "Color" to "Bylayer" (the default) Quote
Lee Mac Posted January 27, 2009 Posted January 27, 2009 Carl, you seem to know quite a bit about macros - I have a quick question: What is the purpose of "^C^C" Thanks Quote
GhostRider Posted January 27, 2009 Posted January 27, 2009 Lee, this is what I've read about the start of a macro: "Cancel Running Commands Make sure that you have no AutoCAD commands in progress before you execute a macro. To automatically cancel a command before executing a macro, enter ^C^C at the beginning of the macro (which is the same as pressing ESC twice). Although a single ^C cancels most commands, ^C^C is required to return to the command prompt from a dimensioning command and ^C^C^C is required based on the current option of the Layer command. ^C^C handles canceling out of most command sequences and therefore is the recommended sequence used to ensure no command is active before the macro is started." I am no expert though, I like to create alot of macros but it seems I have to do alot of trial and error to get one correct, each command seem to act different or combination of commands, CalB's didn't work for me as it is Quote
Lee Mac Posted January 27, 2009 Posted January 27, 2009 Thank you for the information Ghost - I understand things a lot better now. It makes sense to cancel command before starting macros - I suppose the alternative to error handling in LISP. I would be inclined to put ^C^C^C^C in front of my macro going by your post! Thanks Quote
Lee Mac Posted January 27, 2009 Posted January 27, 2009 Ahh, and a modification of Carl's code that may work a little better: ^C^CSELECT;\CHPROP;P;;C;BYLAYER;; Quote
GhostRider Posted January 27, 2009 Posted January 27, 2009 I see now, I got the space after the select but didn't think the semi colon was needed but yes that works perfectly now.. COOL, thanks .. (one day I'll understand all this....LOL) Quote
Lee Mac Posted January 27, 2009 Posted January 27, 2009 In my understanding, I thought that a space/semicolon/new-line all did the same thing - like in a script. But I don't work with macros, scripts much at all, so I could be wrong. Quote
