alijahed Posted January 27, 2009 Posted January 27, 2009 Hi All, Can you please Region this object and tell me how!? It does not work on mine! Cheers Ali Drawing2.dwg Quote
rgarjr Posted January 27, 2009 Posted January 27, 2009 That Poly isn't closed, there's a small gap on there, so that's why it wont region. Quote
DECHAL Posted January 27, 2009 Posted January 27, 2009 Ali, I've looked at this and it appears that your polyline is not closed. Try the pedit command and select close. Then the region command should work. Regards, DECHAL Quote
alijahed Posted January 27, 2009 Author Posted January 27, 2009 Thanks mate, I thought "Join" does the same thing like "Close" in PE! another lesson from u guys Thanks again Ali, I've looked at this and it appears that your polyline is not closed. Try the pedit command and select close. Then the region command should work. Regards, DECHAL Quote
