Help with lisp - Bearing and Distand on line
Airworks
I have a list routine that adds the bearing and distance on a specific layer to a line, however, I want the bearing to display with the degrees symbol not the letter d.
I'm not sure if I can use the (vl-string-subst "%%d" "d" feature with a get selection or where to put this in my routine?)
The lisp routine is below
defun c:lbl(/ oldlay part theight scaleget la_text laname)
; ADDS LENGTH AND BEARING TO LINE
  (command "ucs""w")
  (setq Surv-text_layer_name "SurvTXT")
  (setq Surv-text_layer_colour 7)
(setup_layers)
(SETQ PORTVAL (GETVAR "CVPORT"))
(setq part (getvar "dimscale"))
(setq theight (* part  3))
(setq oldlay (getvar "clayer"))
(command ".LAYER" "m" Surv-text_layer_name "C" Surv-text_layer_colour "" "")
; IF PAPERSPACE DONT MULTIPLY TEXT HEIGHT BY DIMSCALE
   (IF (= PORTVAL 1)
        (command ".DTEXT" "S" "STANDARD" pause 3 PAUSE)
   (IF (> PORTVAL 1)
 (PROGN
 (setq scaleget (getvar "dimscale"))
  (if (< scaleget 2.0)s
  (setq scaleget (* scaleget 1000))
  );end progn
  );endif
 (setq la_text (itoa (fix scaleget)))
 (setq laname (strcat Surv-text_layer_name "_1-" la_text))
 (command "layer" "m" laname "c" Surv-text_layer_colour "" "")
);END PROGN
(prompt "\nSelect lines to label: ")
  (setq ls (ssget)
 len (sslength ls)
 ctr 0)
  (while (< ctr len)
    (setq lin (ssname ls ctr)
   p1 (cdr (assoc 10 (entget lin)))
   p2 (cdr (assoc 11 (entget lin)))
   p3 (polar p1 (angle p1 p2) (/ (distance p1 p2) 2))
   p4 (polar p3 (+ (angle p1 p2) (/ pi 2)) (/ 0.01 (getvar "CANNOSCALEVALUE")))
   p5 (polar p3 (- (angle p1 p2) (/ pi 2)) (/ 0.01 (getvar "CANNOSCALEVALUE")))
    (setq dir (angtos (angle p1 p2) 1 4)
   dis (rtos (distance p1 p2) 2 3)
   tang (angtos (angle p1 p2) 2 4)
    (command "text" "j" "bc" p4 theight tang dir)
    (command "text" "j" "tc" p5 theight tang dis)
    (command ".rotate" pause pause pause p3 "180")
    (setq ctr (1+ ctr))
    (command "ucs""v")
    (command ".layer" "s" oldlay "")
    );end while
  );end function
Like this
   (setq
    (setq dir (vl-string-subst "%%d" "d" dir))   ;; display with the degrees symbol not the letter d.
