attribute name equals filename
grazwelis
Hello..
Could you help me? I am green i Autocad VBA.
Could you help me write vba program for it.
Attributes tags name = drawings filename. Is it possible?
for example i have drawing and when i am opening tags name write filename:
c:\autocad\Test01.Dwg
Block attribute tags name NR1 = test01
c:\autocad\drawing12.Dwg
Block attribute tags name NR1 = drawing12
Thanks
its possible in VBA but it is much easier to just insert a field
This could also be accomplished in LISP if that suits you also.
The necessary information is stored in the following variables:
(getvar "dwgname")
(getvar "dwgprefix")
Depending upon whether you would like the drawing name alone, or the whole filepath written, these variables can be manipulated to suit.
Would you like to proceed with LISP?
Could you make an example? please
I've also never used a field before - Dave could you explain further please :)
when you create an attribute right click in the default value box. One of the selections is "INSERT FIELD". Select "File Name" in the left column and set your options. Press OK and Robert is your dad's brother.
You can do the same if you have already created the block in the attribute editor of your choice.
Sounds good, but is it only in '08? I can't seem to do it in '04. :(
I laughed at this \/
Press OK and Robert is your dad's brother..
Ah, you may have me there. I don't remember what release they came in at, probably 2006. Sorry. :(
No probs Dave, but good solution for if I upgrade - sounds like an easy fix.
Thanks again,
Field is good idea, but VBA I think is better :)
Because we can make more flexible.
For example I need like this:
I have example filenames, and need decode like this :)
Drawing13_1 (Deskription).dwg
tag: Value:
filename...Drawing13
Page.......1
Drawing17_2 (Description).dwg
filename...Drawing17
Page.......2
Drawing01_7 (bla bla).dwg
filename...Drawing01
Page.......7
So i am very green in VBA editing :) I have Autocad2009.
Maybe somebody is wizar in VBA and could give me adwise for that :)
Thanks,
I suppose you could use vl-string-search in LISP to segregate terms...
Sorry for the emphasis on LISP - but my VBA skills are non-existent... :P
it is relatively trivial in VBA using Lee's original post
(getvar "dwgname")
you cn extract the values and then work on them in VBA. You need a bit more code to write them back to an attribute but its not too complicated. however I do have work that MUST come first so I'll leave at this point.....
As Dave says, using the values as I posted, you can retrieve the filename - then either using VBA or LISP, update the attribute accordingly.
Updating an attriute isn't too difficult - just substitution of various DXF codes.
Just to verify -
You have two attributes: Filename, and Page,
and you want the attribute values of these to be the Drawing Name and page number respectively.
Am I close?
The following is a code I used to use to add the filename as a field in our drawing blank.
Public Sub PopCadFile()
'%<\AcVar Filename \f "%tc1%fn2">%
Dim myEntity As AcadEntity
Dim mySelSet As AcadSelectionSet
Dim TempName As String
Dim gpCode(0 To 1) As Integer
Dim dataValue(0 To 1) As Variant
Dim groupCode As Variant
Dim dataCode As Variant
Dim myAttrib As Variant
Dim myCurrentAtt As Variant
TempName = "%<\AcVar Filename \f " & Chr$(34) & "%tc1%fn2" & Chr$(34) & ">%"
gpCode(0) = 0 'item
gpCode(1) = 2 '?
groupCode = gpCode
dataValue(0) = "INSERT" 'item type
dataValue(1) = "STL*" '?
dataCode = dataValue
Set mySelSet = ThisDrawing.SelectionSets.Add("Blocks")
mySelSet.Select acSelectionSetAll, , , groupCode, dataCode
For Each myEntity In mySelSet
   myAttrib = myEntity.GetAttributes
   For Each myCurrentAtt In myAttrib
       If myCurrentAtt.TagString = "CADFILE" Then myCurrentAtt.TextString = TempName
       If myCurrentAtt.TagString = "XXX-XXX.DWG" Then myCurrentAtt.TextString = TempName
   Next myCurrentAtt
Next myEntity
ThisDrawing.SelectionSets.Item("Blocks").Delete
End Sub
ALL our blanks start with STL so I search for a drawing blank. Depending on the age of the drawing the ATTRIBUTE I want is either CADFILE or XXX-XXX.DWG. TempName is the field value, insert your own values in there.
Just to verify -
Am I close?
Of course you all right
Ok, if you don't get on with Dave's code - let me know and I'll see if I can engineer you something to do the job :thumbsup:
