Ok this is getting annoying,
the job i'm doing right now require a lot of pan and zoom and i pan with the middle mouse button and 20% of the time i pan to fast and make a zoom/extent this is really annoying because the drawing is huge and make time to regenerate.
How can i disable the double middle mouse click PLEASE!?
Thanks in advance.
set MBUTTONPAN to 0
This is not solving my problem, i still want to use pan with Mbutton but not the zoom function
Tools --> customise --> interface: Mouse Buttons
:huh:
That just takes you to the CUI doesn't it?... no control for Double Clicking the middle button in there :glare:
TBH I don't think it can be done all without disabling the middle button entirely. :(
:huh:
If you set MBUTTON pan to 0 then the mouse settings in there will apply. Give it a shot.
You will have to try each of the buttons to infer which is the wheel/middle button.
It's button three for me. The middle button only activates pan. To actually pan you have to hold left mouse button as if you have typed pan.
Half an hour and it will seem second nature,and certainly avoid the OP's problem.
