harinezumi Posted July 18, 2019 Posted July 18, 2019 is there a way to merge multiple scale that have the same proportion but different definition? eg: I work in meters and i set scale m1:100 as 1000 paper units=100 drawing units, in a previuos drawing I set m1:100 as 10 paper units = 1 drawing unit. Copying from file to file I end up having m1:100 and 1:100_1 and I have to find all the instances of the latter and change it before I can purge it. Of course they are both 10:1 so it should be easy for a lisp to find them and merge, eventually letting me choose wich definition I prefer. Quote
tombu Posted July 19, 2019 Posted July 19, 2019 I'd save it to DXF, open in an ASCII editor, and replace every instance of 1:100_1 with 1:100. Save and open the DXF with AutoCAD, run AUDIT and pick Yes to fix any errors detected. Quote
harinezumi Posted July 22, 2019 Author Posted July 22, 2019 On 7/19/2019 at 5:01 PM, tombu said: I'd save it to DXF, open in an ASCII editor, and replace every instance of 1:100_1 with 1:100. Save and open the DXF with AutoCAD, run AUDIT and pick Yes to fix any errors detected. will this work even if 1:100 already exist? Can I put it twice in the dxf? Long work around, anyway. Thank you Quote
