hello i try search in the web to understand how i can repeat multiple times this routine but nothing...
(defun C:RT (/ gru)
  (setq gru (ssget))
 (if gru
   (command "_ROTATE" gru "")
   (princ "\nBase point e primo punto d'angolo: ")
   (command pause "_R")
   (command (getvar "LASTPOINT"))
   (princ "\nSecondo punto d'angolo: ")
   (command pause)
   (princ "\nAngolo finale: ")
   (command pause)
i know there is a function called repeat n but i don't know where put it in my lisp..
Try this
(defun C:RT2 (/ osm gru b_pt b_ang )
  (cond ( (/= (getvar 'osmode) 9) (setq osm (getvar 'osmode)) (setvar 'osmode 9)))
  (while (setq gru (ssget))
    (cond (gru
            (setq b_pt (getpoint "\nBase point e primo punto d'angolo: "))
            (command "_Rotate" gru "" b_pt "_R" b_pt)
              (prompt "\nSecondo punto d'angolo: ")
              (command pause)
              (prompt "\nAngolo finale: ")
              (command pause)
    (setq gru nil)
  (if osm (setvar 'osmode osm))
To exit the loop press enter or right click the mouse when asked to select objects.
hello i try your code but is not that i want, sorry.  after the last left mouse click i want that i click with left mouse and repeat the object multiple x times...when i rotate it...
when i finish to copy i press right button.
i have this that copy only one times...
Quote
(defun C:RTC (/ gru)
(setq gru (ssget))
(if gru
(command "_COPY" gru "" (list 0 0)(list 0 0))
(command "_ROTATE" "_P" "")
(command pause)
(command pause)
Edited by jim78b
