PaulMacAD89 Posted July 28, 2019 Posted July 28, 2019 I’ve been a technical kitchen designer for many years, using 2020 Design and Chief Architect. I just started working for a local Design Build that uses AutoCAD full version for all drawings for all trades. I have a background using AutoCAD from vocational training as well as a brief few years doing shop drawings for a millwork company. It’s hard for me to wrap my head around the fact I’m creating cabinets from lines ( floor plan view to elevations ) when I just think of how much time would be saved if using other software. The company has standards for different line types, layers on all the particular plans. They use blocks for the different door styles and drawer fronts appliances, plumbing fixtures etc. I respect it and they do a great job at what they do, but I feel that I could be doing things that aren’t so archaic to make the process quicker and easier from project to project. I’d really like to wow them with some ideas of things that you guys might do to make things easier. Maybe using dynamic blocks (not familiar with the limitations or the process) with different options for door swings? Can you show different line types in a single block? Maybe create a catalog of different size cabinets with different door/drawer configurations. I’m really just looking for ideas and inspiration on things you guys do in similar roles. Quote
BIGAL Posted July 29, 2019 Posted July 29, 2019 Steven-g has done a lot with cabinets he may answer, not my main stream, really automation is what it is all about, don't draw lines, draw doors panels etc You are right dynamic blocks are becoming more the norm and for cabinetry makes a lot of sense. Its about enter length width height number of doors and type all done including cut lists. Have a look in Showcase here and in Particular David Bethel. Are you aware of programming in lisp or VBA .net etc in Autocad. This is a simple example, next step would be the parts list. Quote
steven-g Posted July 29, 2019 Posted July 29, 2019 Yes you can have different linetypes in a block/dynamic block. How are the blocks used by the company you are now working for, a block is usually used just to save on repeating work, so you would draw one door front then use that as a block to place all the cabinet doors then if the design changes slightly edit the block and all the doors that use that block are automatically updated. A dynamic block will allow you to easily use doors with different dimensions to stretch the width and height of the doors, the only drawback of that is that if sizes change then each individual door will need editing separately (unless the dimensions are the same). You can also use visibility states within a dynamic block to turn on/off various features, depending on the needs of a project, just watch out that things don't get too complicated. I find that a big library of simple (size adjustable dynamic blocks) is better than having a smaller library with feature adjustable objects. But that is personal choice and will depend on the workflow that a company uses, and also whether you need to cooperate with others on drawings, it is not much use spending a long time creating blocks that you can use if your collegues have to then work on the drawings and they have no idea how to use the blocks so they explode everything and edit the results manually. But that's all theory, if you could post examples of how things are done, it would be much easier to see how maybe the process could be improved (or not). As BIGAL says the big time saver is automation, so anything you learn with that in mind Lisp, VBA, etc would be of value. Quote
CyberAngel Posted July 29, 2019 Posted July 29, 2019 At one point I worked for a cabinet maker who used Microvellum software. That will do what you want, but it's very expensive. For alternatives, look at WoodCAD or CabinetVision. Revit can produce 3D models, for less money, with models provided by many manufacturers. They use parametric design, which takes a little getting used to. If you stay with AutoCAD and use dynamic blocks, it will take some time to set up a useful system, but you get several advantages. You can always modify/update any part. You can tinker with your workflow until you have something that works for you. Just make sure you organize and document your library properly. Quote
oddssatisfy Posted February 27, 2024 Posted February 27, 2024 (edited) On 7/29/2019 at 3:35 AM, PaulMacAD89 said: I’ve been a technical kitchen designer for many years, using 2020 Design and Chief Architect. I just started working for a local Design Build that uses AutoCAD full version for all drawings for all trades. I have a background using AutoCAD from vocational training as well as a brief few years doing shop drawings for a millwork company. It’s hard for me to wrap my head around the fact I’m creating cabinets from lines ( floor plan view to elevations ) when I just think of how much time would be saved if using other software. The company has standards for different line types, layers on all the particular plans. They use blocks for the different door styles and drawer fronts appliances, plumbing fixtures etc. I respect it and they do a great job at what they do, but I feel that I could be doing things that aren’t so archaic to make the process quicker and easier from project to project. I’d really like to wow them with some ideas of things that you guys might do to make things easier. Maybe using dynamic blocks (not familiar with the limitations or the process) with different options for door swings? Can you show different line types in a single block? Maybe create a catalog of different size cabinets with different door/drawer configurations of Kitchen Renewal Tacoma. I’m really just looking for ideas and inspiration on things you guys do in similar roles. I've been commissioned to build a set of kitchen cabinets that resemble freestanding furniture - FF, inset, painted and "legs" clipped at an angle- they will be a few inches thick. No kicks. Truly a freestanding look. Tops are granite - longest run is about 52" Although freestanding in appearance, they will be permanently placed. I'm struggling with how to secure the "legs." Independently or run the FF to the floor? Independently attached legs will be full thickness Hard Maple. If running the FF to the floor will be 7/8" stock with applied thickness underneath the box. If independently fastened, the bottom rail will leave a recessed area about 1" as the decks will be flush with the rail. Thought about a spacer in this area, then dowels all the way through the decks and into the legs. With the FF running to the floor, how about a cleat along the back wall for support? Ideas appreciated. I'm part-time commission work- no time constraints on this job. Edited February 27, 2024 by oddssatisfy Quote
John G4N Posted January 3 Posted January 3 The downside to most cabinet software, is that it focuses on manufacturing or rendering, but does not offer good detail in the drawings. When 2D drawings and construction detail is required, CAD is the way. I created a pretty extensive library of Dynamic kitchen cabinetry blocks that accommodate thousands of options using the dynamic actions and viewstates. This has cut the design process from days to hours, putting out highly detailed shop drawings for the customer and the shop with all the necessary details and then some. It did take a while to learn all of the capabilities and then build a base system from which all the future blocks can be created and modified so they follow a similar logic. Anything that can be drawn in 2D can be incorporated into a block, including lineweights, hatches, colors etc. Static block can also be incorporated into the dynblocks for hardware or other inserts. Quote
Harborview_kitchens Posted 3 hours ago Posted 3 hours ago I can definitely relate to what you’re experiencing. Jumping from 2020 Design or Chief Architect into full AutoCAD can feel like going back in time, but there are ways to make it a lot more efficient. Dynamic Blocks: These are a huge time saver once you set them up. You can create cabinet blocks with adjustable dimensions, door swings, and drawer options so you’re not redrawing the same thing every time. Block Libraries: Build a catalog of common cabinet sizes, appliances, and fixtures. Organize them by layer/line type so they’re consistent with company standards but quick to drop in. Layer States / Filters: If the company already uses strict layer standards, you can make templates or saved states so you’re not manually setting them each time. Annotative Objects: For text, dimensions, and hatches, using annotative scaling can save a ton of headaches when producing multiple plan sets. Xrefs: If multiple trades are involved, external references can help you keep drawings cleaner while still coordinating. It might take some upfront setup, but once you have a library and dynamic blocks in place, the workflow will be much smoother. It also shows initiative if you build tools that others on the team can reuse. Quote
