lgrammel Posted August 5, 2019 Posted August 5, 2019 Hello, I have a highly repetitive task that I am trying to automate and looking for a way to do this... Copy files from Mechanical Directory "Model" (eg filename "Drawing1.dwg") paste in new directory "ELEC" and rename/ saveAs with -ELEC at end (eg filename "Drawing1-ELEC.dwg) Delete the contents Overlay mechanical DWG from the "Model" directory (XREF @ 0,0,0) (there can be 50+ mechanical drawings) Save Move on to next drawing in the "Model Directory (eg. "Drawing2.dwg") Repeat for next Mechanical DWG… Example: Project A has sub folders "Model" So I need to create subfolder "ELEC". The file "Mechanical1.dwg" in the "Mech" folder means that I need to have a "Mechanical1-ELEC.dwg" in the "ELEC" folder such that the drawing has the XREF to the "Mechanical1.dwg" file. Then I need to repeat for all .dwg files in the Mech folder. Quote
Emmanuel Delay Posted August 7, 2019 Posted August 7, 2019 I can help you with 1 to 5. Then you still have to perform the routine multiple times, but it should still help. A few questions: - First, what do you mean with 3? Delete contents of what? - Can you repeat a bit more clearly which files are where? Which must be attached (overlayed) to which? Maybe you can give an example with absolute locations (example main file: "c:\usertemp\project1\drawing1.dwg" ...) Here's what I did: - main file: "C:\UserTemp\xref_copy\Mechanical.dwg" - folder to read files from: "C:\UserTemp\xref_copy\Model" (files "Elec1.dwg" "Elec2.dwg") - folder to write new files to: "C:\UserTemp\xref_copy\ELEC" - Then "Mechanical.dwg" gets xrefs: "C:\UserTemp\xref_copy\ELEC\Elec1-ELEC.dwg", "C:\UserTemp\xref_copy\ELEC\Elec2-ELEC.dwg" Quote
rlx Posted August 7, 2019 Posted August 7, 2019 To get you started (site is called cadtutor for a reason) Begin with an empty drawing ;;; https://www.cadtutor.net/forum/topic/68409-automate-drawing-creation-overlay-xrefs/ ;;; Example: Project A has sub folders "Model" So I need to create subfolder "ELEC". ;;; The file "Mechanical1.dwg" in the "Mech" folder means that I need to have a "Mechanical1-ELEC.dwg" ;;; in the "ELEC" folder such that the drawing has the XREF to the "Mechanical1.dwg" file. ;;; Then I need to repeat for all .dwg files in the Mech folder. (defun c:t1 ( / doc sourceFolder targetFolder dwg-list dwg-name) (if (and (setq doc (vla-get-ActiveDocument (vlax-get-acad-object))) (setq sourceFolder (getfolder "Select folder with source drawings" "" nil)) ;;; replace sourcefolder with "" if targetfolder is not a subfolder in sourcefolder (setq targetFolder (getfolder "Select folder to create new drawings" sourceFolder T)) (vl-consp (setq dwg-list (mapcar '(lambda (x)(strcat sourceFolder "\\" x)) (vl-directory-files sourceFolder "*.dwg" 1))))) (foreach dwg dwg-list ;;; create name to save drawing (setq dwg-name (strcat targetfolder "\\" (vl-filename-base dwg) "-ELEC.dwg")) ;;; remove all xrefs if any (vl-catch-all-apply 'vl-cmdf (list "-xref" "detach" "*")) ;;; attach dwg as xref (vl-catch-all-apply 'vl-cmdf (list "-xref" "overlay" dwg '(0 0) 1 1 0)) ;;; save the drawings (vla-saveas doc dwg-name) ) (prompt "\nFunction cancelled") ) (princ) ) ;;; $msg = message, $def = default path , %new = display create new folder option (t or nil) (defun GetFolder ($m $def %new / sh fol pFol path) (vl-catch-all-apply (function (lambda nil (setq sh (vlax-get-or-create-object "Shell.Application")) (setq fol (vlax-invoke-method sh 'BrowseForFolder 0 (cond ($m)(""))(if %new 0 512) (cond ($def)((strcat (getenv "userprofile") "\\Desktop\\"))))) (setq pFol (vlax-get-property fol 'ParentFolder)) (setq path (vlax-get-property (vlax-invoke-method pFol 'Parsename (vlax-get-property fol 'Title)) 'Path))))) (foreach x (reverse (list sh fol pFol path))(vl-catch-all-apply 'vlax-release-object (list x))) path ) Quote
BIGAL Posted August 9, 2019 Posted August 9, 2019 Would using the vl file functions be easier than using shell ? Quote
rlx Posted August 9, 2019 Posted August 9, 2019 3 hours ago, BIGAL said: Would using the vl file functions be easier than using shell ? if you're taking the copy & erase road ....maybe , something like (command "sh" "copy c:\projectA\model\*.dwg c:\projectA\elec\*-elec.dwg") or whatever. Starting with empty dwg and using xref & saveas no need for copy , erase & purge etc. But I'll leave that choice to OP , his (or her) party... Quote
