Copy and Paste not working in autocad layout
RepCad
Hi all, I have had a problem with copy and past in layouts in which case copy and paste only work for 2 or 3 times in layout and after the times copy and paste doesn't work at all and I have to quit and start again my drawing file. does anyone know how to resolve that problem??
This happens to me every once in a while. When it does, I run an AUDIT. It never finds any errors but it clears out whatever is stopping the copy paste from working.
Does that mean your problem is solved by AUDIT command??
Yes, it fixes the problem for me, when it occurs. But like I said, it only happens every once in a while. It sounds like your issue is more frequent?
Try running an AUDIT next time this happens and see if it helps.
Yes, it happens every once in a while and I tested AUDIT  command , it didn't work for me.
Edited by amir0914
